-   -   Fixing odometer (http://forums.pelicanparts.com/porsche-911-technical-forum/589909-fixing-odometer.html)
prebordao 02-05-2011 10:15 AM
Fixing odometer
The odometer (total and trip) on my speedo suffers from a common ailment: sometimes it works, sometimes it don't (more often)...
I happen to have the "guts" of a working speedo from a 70'T. This one still has metal gears unlike my 74' which has plastic ones, I believe.
Is it possible to transplant them into the a 74' speedo ? will it work ? both are mechanical, but...
Chris Morse 02-05-2011 10:32 AM
My 74 also has a funky, (inoperative) odometer.
Page 209 in the 101 projects book has a good write up on it. I have just had a few more pressing issues.
Looking forward to seeing how yours comes out.
chris
Kraftwerk 02-05-2011 11:35 AM
I would say you have to take them both apart and compare the two gears. Replacement gears are available. I have done it, but them i twacked the needle and screwed the all works and ended up having to send it in anyway, lost time and money but, oh so much experience..
bfunke 02-05-2011 11:52 AM
North Hollywood Speedo or Palo Alto Speedo. Quality work and fair prices. To keep your Porsche odometer healthy - never ever reset the trip meter when the car is moving.
rattlsnak 02-14-2011 10:35 AM
Where can you get replacement parts? NHS and PAS will not sell them outright..
Kraftwerk 02-14-2011 11:01 AM
(HINT: there's a new invention called: GOOGLE!)
Odometer Gears | 72 Croatan Road | Newport News, VA 23606 | 757.593.3478
The gear itself is a cheap-easy fix but I snapped off the "speedo-pointer" when re-assembling the thing and had to send it to North Hollywood who did a great job btw
pete3799 02-14-2011 12:07 PM
I believe Wayne (Pelican) is now selling those also.
E Sully 02-14-2011 12:34 PM
Not a hard fix, just be careful and patient removing the needle.
Porsche 911 & Carrera Gauges and Miscellaneous - Page 4
Woodyhfd 02-14-2011 12:36 PM
FYI to anyone who's tripometer is not working:
A couple of years ago, I sent my speedometer to North Hollywood Speedometer for a rebuild. My odometer was working fine, but the speedo was not.
After I got it back, everything was working fine except the trip odometer, which worked before. I found that the reset button wasn't releasing all the way, which was preventing the numbers from turning. It loosened up after a bunch of resets, but I always make sure that it has fully released each time I reset.
88911coupe 02-14-2011 01:15 PM
Sorry to piggyback. I did the gear fix last summer which worked fine till last week when I noticed my odometer jumped from 177xxx to 277xxx. How the heck do I fix that!?
rattlsnak 02-14-2011 07:01 PM
Not sure how it happened unless something went back together crooked, but if you take it back apart you can "adjust" the mileage to where it should be.
