-   -   wheels and handling (http://forums.pelicanparts.com/porsche-911-technical-forum/58995-wheels-handling.html)
carlos 02-04-2002 02:47 PM
wheels and handling
can anyone tell me weather switching from 6 and 7 by 16" wheels to 7 and 9 by 16" will affect the handling of my 85 carrera? thanks!
nhromyak 02-04-2002 03:07 PM
OHHH YEAH baby!!!! :D :D :D :D
I get some understeer now... 205 fronts. The rear 245/45/16s are REALLY hard to break loose comparing to when I had 7s in the rear.
When auto-xing I usually power slide the rear end, as opposed to before, with 7s, I went around. It almost seems more difficult to recover from a rear slide with the 9s, but then again, I had near bald tires then. :D
carlos 02-04-2002 03:25 PM
nick,
so you would reccomend this change? your car handles better overall?
thanks so much.
carlos :confused:
nhromyak 02-04-2002 03:37 PM
I would say it gets a little light in the rear when it rains. These spin easily.
I am running Bridgestone Re730s 205/55-16 and 245/45-16.
Others say they have had little to no problems.
I like my Yoko better in the dry, worse in the wet.
I will go with 225/50 fronts next time. This should reduce the inital front end push. I am quite low now after a corner weight check.
The biggest benefit I think so far has been to get a four wheel alignement. :D
What kind of driving do you do?
