gduke2010
Oil leak
I have an oil leak on the right rear near the oil tank and hose coming from the tank. today, I jacked the car up and looked at what I thought would be a bad hose. And upon inspection it appeared that oil might be coming from a cover above the hose.
BTW, the hose looks like it needs to be replaced. Is that the cam cover above the hose? Here is a pic. Hopefully, someone can diagnose. ![]() Thanks, Gary |
gduke2010
The engine is a 1995 3.6 which I had installed about 10 yrs ago.
Gary |
gduke2010
Also found a missing bolt on the engine tin. This might be whats causing the vibration noise coming from the engine compartment.
gduke2010
Cleaned up the area and took another pic. You can also, see the missing bolt.
I'm thinking this might be wheren the vibration noise is coming from. gary
gduke2010
