-   -   swinging idle and stalling while driving (http://forums.pelicanparts.com/porsche-911-technical-forum/590208-swinging-idle-stalling-while-driving.html)
911cedric 02-06-2011 06:34 PM
Hello,
another challenging issue with a 95 porsche 993 Carrera;
idle swings a lot when accelerating, and the car often stalls when driving fast as i release the clutch; it's very dangerous because as the power cuts, the breaks and the steering becomes suddenly ineffective.
i scanned the car many times with PST2, without pulling any error code;
i swapped from a clean car, idle valve, MAF (air flow sensor), flywheel sensor,
but nothing changed.
i checked all the vacuum system, and checked tightness of all hoses; nothing
i checked the exhaust for leaks; still nothing
I only noticed that when the MAF is unplugged, the car seems to idle better but not perfect, with always a kind of rebound when the rpm comes back to 900.
i will try again another MAF and will test my alternator charge signal.
the only weakness i know of this car is the clutch which seems to be shaky, but the engine is fine.
I'm getting short in ideas
Bill in OKC 02-06-2011 10:08 PM
O2 sensor?
