-   -   Rebuild 3.0 or install 3.2? (http://forums.pelicanparts.com/porsche-911-technical-forum/590243-rebuild-3-0-install-3-2-a.html)
papa (guest) 02-06-2011 10:05 PM
should i rebuilt my 1978 3.0 911 engine{3 broken head studs amd 144,000 miles} or should i install a rebuilt 1986 3.2 911 engine for same price {has 92,000 rebuilt at 80,000}. is the 3.2 a better engine?why or why not?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: 911 Engine Removal Made Easy
Wayne 962 02-06-2011 10:05 PM
The 3.0 and 3.2 are nearly identical, and suffer from nearly the same issues. To rebuild the 3.0 is expensive these days (but still fun!). If you didn't do the rebuild yourself, then who knows what's actually in the 3.2 as well. It's really a crapshoot. Also, you'll have to update your car to run the 3.2 Motronic system, which is not too difficult, but involves a bunch of different steps (you'll need a new tachometer that is matched to the 3.2 computer too).
- Wayne
T-Bone911 02-07-2011 07:22 AM
I went with the 3.2 last year. For about the same price you get a better fuel injection system more torque and a little more power. New tach, computer and wiring harness required. Could not be happer, well a 3.6 would be better but not in my budget last year.
LakeCleElum 02-07-2011 07:36 AM
If you can verify the work to the 3.2, go that way and sell your 3.0 as a core for $2K or more. You'll come out ahead in time and money, not to mention a more modern fuel and ignition system.
