rear deck upholstery - 911
gents
can you direct me to the thread related to replacing the 'rear deck' upholstery -- material behind the back seats in a 911 tx
ed ed's flyfishing outfit bozeman, mt '92 964 C4 chevy p/u |
I'm on for this one, for sure. As I just TORE my covering while addressing speaker issues....haven't yet begun my search on materials,..looks to be an easy job...yet, I,..like you,..would prefer the original materials....
let's roll.. Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Free minder
I redid mine with some marine vinyl I bought at Joann (sp?) fabric store. It worked fine and I am happy with the result. Only problem is the closest color to match my cork interior was beige, and it is not that close...but black should work great. It really is easy to do: unscrew and remove he whole piece, remove old covering material, staple new in, trim, reinstall. Vinyl is easy to work with because it stretches a bit.
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) Last edited by Aurel; 02-12-2011 at 05:02 PM.. |
I went back with leather... I had my dash recovered and at the same time I order enough extra leather to cover the package tray. However the under lament was badly warped from the old leather shrinking so I had to do a lot of repair to the under lament before covering with the new leather. I think the vinyl will take the sun better, but I wanted to go back with original to my car.
If you're going to make any changes or upgrades to your speakers, now would be the time to do it...
Mitch Leland "03" 996 C2S-LS3 V8-480 HP "84" 911 Turbo Look-Sold w/ found memories |
I've been looking for a while for someone to help me that does not break the bank. /Johan
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452) 911E Coupe -70 Carrera 3,2 -84 Sold |
O2 In Sully We Believe |
Dash Recover...
I had Tony Garcia of Autobahn Interiors - San Diego, California repair the under lament structure and recover the dash. The recover was $650. Tony did a fine job. This work was done about year ago. Tony's e-mail address: info@autobahninteriors.com
anyone know where to get the board for the parcel shelf. I have a targa and the board is all warped. If i can get the board I can get it recovered locally, Thanks Jerry
6 cylinder symphony
Guys -
applied business concepts (appbiz). They supply Pelican. Applied Business Concepts Call Bob. He's awesome. Ken
'84 3.2 Targa '89 964 Coupe "What do you mean NEXT project?" - my wife |
be here now
I went a slightly different route.....since it's an "outlaw"
Rob.... '66 911, '74 911, '85.5 944, '69 914-6, '65 356C, '01 986, '04 955S, '97 993 C2S, '55 356 OUTLAW, '98 993 Cab, '55 356 Speedster, '06 955S, '58 356A, '96 993 C4S, '87 BD 911, '95 993, '06 997S, '11 997.2S, '74 914 2.7, '15 981S |
Straightening a warped Package Tray...
Because mine was covered in leather it had shrunk and warped the under lament. I took a damp towel and a steam iron and got mine back pretty flat. However the laments of the board opened up from the steam so once the laments had dried out I poured epoxy down into the openings, (covered the area with Saran Wrap) then clamped 2X6 boards top and bottom until the epoxy had set up. Because I have the equipment, I lined the top and bottom edges with .030" alum. and riveted the doublers together so the board won't warp again. ![]()
