-   -   Intermittent trouble finding third gear? (http://forums.pelicanparts.com/porsche-911-technical-forum/590432-intermittent-trouble-finding-third-gear.html)
grahamkissack 02-07-2011 10:11 PM
I seem to intermittently have trouble finding third gear .... almost like I either find it perfectly or am way of course and end up getting a significant grinding like one spinning gear hitting another. I replaced the shift coupler bearings as well as all the other shifter bushings in 2004 and everything stills looks perfectly smooth with no play. I also just re-adjusted the coupler and can easily find 1,2,3,4,5 and R. The car has 100,000 miles ... second gear dog teeth are slightly worn as its getting a bit finicky but its still pretty good. Swepco tranny fluid too.
Any thoughts?
DRACO A5OG 02-07-2011 10:30 PM
Hmmmm, have you considered flushing the Swepco and using Kendal 80W90 (with LSD if you have it)
If you do change it will take 2-3 changes to get all the Swepco out after 1000+miles each time.
Just my 2 cents, I had shifting issues and now it shifts like a normal car.
yelcab1 02-08-2011 01:14 AM
Synchro is worn.
