Ubi bene ibi patria
Am I screwed?
This may be more suitable for the 'Paint & Body Forum', but here goes anyway.
![]() Can this front lens be repaired by some type of glue or bonding process? I done the 'search thing' & have come up a bit short. I would like to have input from board members on this seemingly simple question. I really don't want to mess this up & have it look like a 'hack' repair job; then have to go to the expense & bother of finding a replacement lens. It does appear as though it was previously glued/repaired by a PO with 'crazy glue' or something similar. It simply fell apart when I removed it from the car. Thanks in advance & Cheers JB Go Canucks |
If you glue it it will crack again because of the three screws that hold it in place. Just get a new one.
72 911 Although it is done at the moment, it will never be finished. |
yes screwed
1988 Carrera Coupe |
Break out the piggy bank....
Neil 1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic (X) [B] 2011 BMW X5[B] 'Success is not final, failure is not fatal. It is the courage to continue that counts' |
If you really want to patch it together and take a chance, try using E6000 Glue.
To use, clean the mating surfaces with Isopropyl Alcohol followed by Acetone. Allow to dry. Apply a bead of E6000 to one side and hold the two halfs together for about 2 minutes (it will seem like several eternities). Put the piece down somewhere where there will be no stress on the new joint and allow to set for two days. Sometimes this works, sometimes it don't. You can try to reglue the joint if it fails the first time. You will always see the crack.
Banned but not out, yet..
My suggestion: Post on the classifieds here and on the Early 911S Registry: WTB Front turn signal lense for 19XX 911. People will repond with parts.
An air cooled refrigerator. ‘Mein Teil’ |
Ubi bene ibi patria
Thanks for the feedback guys. I'll try Harry's suggestion for the short term fix. I guess I'll have to lash out buy a replacement. Again, much appreciated.
Cheers JB |
fancytown
Is that the front turn signal lens?
I cracked mine in 5 or 6 pieces when a parking ramp decided a speedbump should be right at the bottom of the ramp. My bumper (fiberglass) was ripped off, and this lens cracked from the bumper. This was all trying to go as sideways as possible over it (couldn't back up). I epoxied my lens for the time being, and bought a replacement in the process. LOL, my replacement has been sitting in my basement for 3 years because I never notice it on the car until I get really close.
all cars sold. |
gjs
I have one from an 88 911 if u r interested pm me. Glenn
88 911 Carrera Cab, SW chip, B&B headers, custom sport muff 2015 Cayman S 1948 Willy's Overland Jeepster 2013 Chev Sub 2004 Nisson Xterra |
83 911 Production Cab #10
As tobluforu mentioned, its the 3 screws mounting that will screw you up... Might want to use only 2 screws for the short term fix.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
