Question 911 Gearbox?
I have a 356 replica that has a 5 speed gearbox fitted to it that I was told is originally off a 911. The only markings I've found to date are the numbers 7150638 that are stamped on a flat face on the underside of the box.
I've recently had a problem with the gears jamming so I need to know what I'm dealing with.
Can anyone identify the gearbox from these numbers?
Many thanks for all/any feedback
Ross
Old 02-06-2011, 11:36 PM
Could it be 7190638. That would make it a 901/07 which
you should find stamped further along the bottom rib toward the
front of the car.
Gears would then be 11/34 (A), 18/34 (F), 22/29 (M), 25/26 (s),
29/23 (Z).
andy
Old 02-07-2011, 03:02 AM
djpateman's Avatar
715 would indicate a 1975 915 transmission. Look to see if there is a 915 designation near the serial #. Other choices are 911 (1970 & 1971 only), 901 or 902 (1965 to 1969). Post a photo of the side of the transmission.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 02-07-2011, 01:44 PM
Thanks guys, my mechanic is in the process of dropping out the engine and gearbox, so hopefully we'll be able to find the other markings once we can get it cleaned and under some decent light.
Old 02-07-2011, 09:40 PM
We finally located the number 915 101 301 OR embossed on the bell housing.
Can anyone tell me the year, which original 911 models it was fitted on, and the standard gear ratios?
Many thanks
Ross
Old 02-07-2011, 11:43 PM
djpateman's Avatar
so the 915 part # says it is a 915 transmission, and the serial # says it is a 1975 5-speed
type 915/40
1st – 11:35
2nd – 18:33
3rd – 23:29
4th – 26:26
5th – 28:23
R&P – 8:31
Addicted since 1975
Old 02-08-2011, 05:43 PM
Thumbs up
Hey, many thanks for your feedback.
The road test speeds that I recorded when the car was running match the Pelican 915 spreadsheet calculator almost exactly using the cog ratios you've provided - so it looks like you're right on the money.
Cheers
Ross
Old 02-08-2011, 11:19 PM
