For bending the fuel (or brake) lines in the engine compartment & up by the fuel tank. You could take this extra step. Buy cheap windshield wash hose and run a hanger or an equivalent wire through the hose bend it as you wish, and presto, you have a perfect template to bend your new lines by. Saving your real lines for the final steps. I'm using aluminum with flared ends & clamped EFI rubber hose combo. I prefer to keep the connections to a minimum.
Chow http://www.pelicanparts.com/more_inf...59685-3164.jpg __________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Replacing 914 Gas Lines in the Center Tunnel |
Neat tip, thanks for sharing!
- Wayne |
Great idea!
| All times are GMT -8. The time now is 03:13 AM. |
