-   -   Quick question (http://forums.pelicanparts.com/porsche-911-technical-forum/591229-quick-question.html)
steveinfl 02-12-2011 08:12 AM
Quick question
This should be easy for you guys. Is the dash in a late eighties carrera the same as a 964? I bought a 964 dash for my 84 and need the defrost trim piece. I just wanted to make sure if I bought the defrost trim from a late eighties it would fit the 964 dash.
Thanks in advance.
H-viken 02-12-2011 08:23 AM
As far as I know the design of the dash changed 1986. Not sure if you can make a post-86 dash fit a car from 1984. Maybe someone else can chime in.
/Johan
NewfieMZ3 02-12-2011 08:46 AM
You are correct, it changed in 86.
steveinfl 02-12-2011 09:36 AM
Thanks for the help guys. I have actually put the 964 dash in my 84...with some metal cutting and hole drilling. I now need to get the defrost trim piece to complete the dash. I just want to check that if I buy one from a post 86 carrera, it will match up with my 964 dash.
