ischmitz's Avatar
Send a message via Skype™ to ischmitz
Question Which oil for 915 tranny is the best?
Please let me know your opinions for what oil or mix is recommended for everyday driving.....
The tranny is in good condition and shifts nice and smooth if I don't force it into first like crazy. Well, you simply don't force a 915 at all, right.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 07-01-2002, 09:16 PM
The consensus is Swepco 201... available right here at Pelican Parts...
Scott
Old 07-01-2002, 10:15 PM
Warren Hall Student
Bobboloo's Avatar
Ditto, Swepco. The most important thing by far is just changing it on a regular maintenance schedule regardless of the brand. (Don't we wish previous owners had done so.)
Bobby
Old 07-02-2002, 01:43 AM
Information Junky
island911's Avatar
I was under the impression that swepco was for after the syncro's are worn and no longer shifting smoothly. . . .kind of a last ditch effort to get the syncro's to grab a bit better. (?)
Old 07-02-2002, 08:10 AM
ischmitz's Avatar
Regular changing means once every year from what I understand, correct?
Do people change more often or less based on mileage and/or track (ab)use?
Ingo
Old 07-02-2002, 09:24 AM
Warren Hall Student
Bobboloo's Avatar
Once a year is what I do for all my cars. I would imagine the racing crowd changes more often. Maybe someone could enlighten us. Jack, Randy, anyone?
Old 07-03-2002, 04:57 AM
Chris Lovell's Avatar
Swepco for my 915. Tried Mobil 1 and went back to Swepco as soon as UPS could deliver. I don't think the age or wear concern would move me off Swepco.
CWL
'88 Carrera Cab
Old 07-03-2002, 05:25 AM
rstoll's Avatar
Clean
Robert Stoll
83 911 SC
83 944
Old 07-03-2002, 05:46 AM
Senior Member
Jdub's Avatar
A bit off the subject, but if you do a R&R on the oil, do drop the 915's belly pan and tighten up the shift fork. Also consider getting one of the magnetic plugs for the fill-side plug. And of course as said by better minds than mine do pull the fill plug first as you don't want to find out later that this plug is stuck and you with it!
Also, I go with Swepco at this time. Trans is just rebuilt with about 2K on it.
John
'78 Targa in Minerva Blue
Old 07-03-2002, 11:32 AM
Early_S_Man's Avatar
Porsche Crest
Not a bad idea, John, but a few folks may need a translator!
The cover plate #5 is what John is talking about 'dropping' and the guide fork #6 is what needs to be tightened -- held on by three M6 nuts -- #8! A new gasket will be needed, and be SURE to clean the plate and everything attached to it with brake spray cleaner/degreaser ... before applying blue Loctite 242 to the three studs and torqueing the nuts for the guide fork! It wouldn't hurt to 'treat' the gasket with Loctite 518 before assembly, either!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 07-03-2002, 12:03 PM
Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
I am about to replace the gasket (#9), mine is leaking fluid. When i do remove the plate (#5), should the car be in neutral or in a gear, or does it matter? Also, i have been told before, but what is the torque on the M6 nuts(#8) and what i think are M8 nuts(#11)?
As always, input is greatly appreciated.
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 07-03-2002, 12:15 PM
Porsche Crest
Kemo,
Per the '78-'61 spec book ... cover plate M8 nuts get 22-25 Nm, or 16-18 lb-ft.
Guide fork M6 nuts get 8-9 Nm, or 6-7 lb-ft.
Shifter in neutral would be my choice, but it probably doesn't matter!
Warren Hall, Jr.
Old 07-03-2002, 12:35 PM
Black and Blue
Kemo's Avatar
Warren,
thanks for the info...again!
I just had a case of deja-vu...
Kemo
Old 07-03-2002, 12:58 PM
pwd72s's Avatar
SWEEPCO! (I however, continue to use a synthetic..TORCO 75-140 GL6 with limited slip additive. And I believe the car shifts better & the gearbox internals do better than they did when I ran sweepco. But I sure ain't Bruce Anderson!)
Old 07-03-2002, 05:59 PM
