Mawa911sc-targa
Mawa's Avatar
Porsche Crest Oil falling of the gearbox, and yellow cream, in 911 sc
Hello everyone, I am new and I had a problem with my Porsche 911sc that is falling oil from the gearbox, I just bought it, and I do have another question, I found yellow cream in the oil plug when I open to measure the oil.
Cheers,
Old 02-07-2012, 02:53 AM
Oh Haha's Avatar
Are you capable of making repairs to the car? If not, have your mechanic look it over.
Gearbox leak could be a simple gasket that needs to be replaced. You need to locate exactly where the leaks originates to get more specific help.
The yellow cream in the oil cap is condensation. Likely casued by the engine not run untill up to temp in a cold climate. It isn't a death sentence but I would consider driving the car more.
Are you checking the oil level correctly? Car up to normal temp, on level ground, running. The accepted level is about halfway between the two hash marks on the dipstick.
Hope this helps.
Pacific Blue
Wayne
Old 02-07-2012, 03:56 AM
KNS KNS is offline
Yellow cream: You aren't driving the car long enough, there is a lot of oil to heat up. Take it on a long, hot drive.
Kurt
Old 02-07-2012, 07:56 AM
On the trans, either a seal or if its off the top, the breather is not in correctly.
Bruce
Old 02-07-2012, 09:09 AM
In the Winter I use a few less quarts of Oil! I put in 8 instead of 10. If you do not drive more than 15 to 20 miles each way the oil will get contaiminated with water. That is why only my wife drives it in the winter she is 20 miles from work and I am 4 miles away. In the Mini Cooper I have a water collector attached to the Engine Vent tube. I need to drain it every 5 ot 6 weeks! It holds about 8 ounces
Made History at Daytona and Still one Fast Old Man! 1982 Porsche 911 SC & 2017 Honda Si
Old 02-07-2012, 09:40 AM
Mawa911sc-targa
Mawa's Avatar
Thanx guys, It was a long ride, 1000 miles, aprox From Holand to Spain.
But it was the coldest week of the year, so I got stuck close to Paris because I had a electric problem that the car did not start, my insurances toke it to a garage and they told me that it is the starter, an I will continue the travel next week.
I do have another question, my gearbox scratching sounds changing the gear, and I am not sure if I am doing wrong or the clutch or the gearbox is not well.
I introduce oil to the max... I have to do it to the middle?
I am really new with the car, sorry for my stupid questions.
Thanks a lot
Alvaro
Old 02-07-2012, 02:18 PM
flat6pilot's Avatar
Some will keep the oil level about in the middle of the dipstick notches. That way you'll have a little room to prevent overfilling and avoid introducing oil into the intake system that could cause heavy white smoke out of the exhaust.
Try halfway and check that your oil pressure is good. (remember to do this on a level surface) Should have around 3 bars at idle.
There are no stupid questions!
Kyle
1980 911sc 3.2 Turbo, 930 Trans
2006 BMW 330i 6mt (DD)
Old 02-07-2012, 02:48 PM
Mawa911sc-targa
Mawa's Avatar
Thanks a lot
About the gearbox that scratches up is gearbox problem or clutch problem?
It is rare because driving fast and high rpm do not scratch, and driving with low rpm, scratch a lot.
Always in first gear, when I just start up the car, it scratch a lot too.
Cheers
Old 02-08-2012, 01:18 AM
Enthusiast
jrolstin's Avatar
3bar at idle cold? Depends on the type of oil you run.
Jonathon
1982 911 SC
www.avrmotorsports.com
Old 02-08-2012, 01:26 AM
Mawa911sc-targa
Mawa's Avatar
I run 5-40 oil, that it is the most liquid one in Europe. I do not know in US, sorry.
Cheers
Old 02-08-2012, 10:24 AM
