Floor board installation question. '88 Carrera
What is the trick to floor board installation; can this be done without removal of the pedals? What is the purpose of the hardware around the clutch slot?
Old 02-15-2011, 06:54 AM
winter
Winter's Avatar
On my '75 i have to "pop" the gas pedal off to fit the floorboard. On the '75 you can just pull straight up and out, it stays connected on the bottom, but there's a ball + socket type connection about halfway up it. get down under there and take a look to see if yours is the same.
Good luck!
Tom
'76 Targa
Old 02-15-2011, 08:14 AM
French Import
zippy_gg's Avatar
Yes the floor board can be removed with the pedals still in place. I just did that as I am replacing the floorboard and carpet in my 86 cab. Removing the rubber pads on the pedals may help if that is your issue.
I am not sure I understand your second question... Can you post a pic?
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 02-15-2011, 08:15 AM
schumicat's Avatar
the hardware around the clutch slot is a clutch stop. It limits how far the pedal can travel (and thus the amount of travel up before the clutch starts to bite) and is adjustable.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 02-15-2011, 08:18 AM
Thanks guys!
Appreciate your advice on this. The gas pedal was in fact the stopper as I was able to get the fb over the clutch and brake pedals. I was short of time and didn't want to yank on stuff willy nilly. yaz
Old 02-15-2011, 08:51 AM
