-   -   Rust protection scheme (http://forums.pelicanparts.com/porsche-911-technical-forum/592061-rust-protection-scheme.html)
SorenDK 02-16-2011 10:20 AM
Hi
I live in the cold nordic european Denmark and some kind of rust protection is really important here especially because i have a f-model coupe from 1969 - Does anyone have some kind of rust protection spraying scheme for this car thay want to share?... Some explaination is probably necessary since Im not sure what its really called:
Some kind of illustration, scheme or similar which outlines where to spray different types of rust protection + where to drill small holes in order to get the rust protection sprayed properly into sills etc?
rsrpedi 02-16-2011 10:29 AM
rust
hi there, try to find a company who is working with mike sanders products.
let them do it for you...not home made. its need to heat up and itīs better done this before. cheers peter
faverymi 02-16-2011 11:14 AM
Try the POR-15 website.
It will give you a really good protocol for rust protection and prevention.
Don't know if they ship to scandinavia but at least it will guide you.
Cheers.
Wil Ferch 02-16-2011 11:58 AM
Porsches up to about 1989 suffered greatly in not having plastic fender liners. Even the later galvanized cars suffer a great deal in bad weather because the "junk" that gets crammed into all the internal spaces and crevices.
Besides the rust-proofing or undercoating you may find and consider....also use the plastic fender liners....example--->
Lokari.de
Porsche listings ----> http://www.lokari.de/en/interior_mudguards_search.php3?select=porsche&acti on=search
Hesse James 02-16-2011 02:26 PM
Hello Soren,
have a look here in this post:
http://forums.pelicanparts.com/porsche-911-technical-forum/436894-1975-911s-sporto-cosmetic-restore-2.html
best regards
Heiko
