-   -   CAT bypass on 84 Targa; good idea or not? (http://forums.pelicanparts.com/porsche-911-technical-forum/592124-cat-bypass-84-targa-good-idea-not.html)
JCoop 02-16-2011 02:31 PM
:confused:
Does anyone have any recommendations regarding the wisdom of a CAT bypass ? Does it appreciably increase horsepower ? Is it easy to remove for a smog ?
bornrich 02-16-2011 02:46 PM
I use a cat bypass on my 81 and it does affect the performance not by a whole lot but it does help also it gives the exhaust note a deeper tone.
Oh Haha 02-16-2011 03:06 PM
It will help the exhaust note but you probably won't notice much of a power increase.
Now, do the bypass along with a sport muffler(M+K, hint hint;))and you WILL feel an increase.
You could keep your stock setup for smog certification time. You will most likely have to adjust the air/fuel mixture when switching between the 2 setups.
gtc 02-16-2011 03:50 PM
Removing the rusty bolts holding it on will probably be the hardest part.
If I were in CA, I would just leave the exhaust intact and buy a chip from Steve Wong.
450knotOffice 02-16-2011 04:07 PM
Remove the Cat and buy a Steve Wong chip and you WILL feel a difference. BTDT.
jlynch1960 02-16-2011 04:14 PM
I just put the cat back onto my 84 Targa. PO had gone to a bypass and sport muffler. The model year is exempt from emissions inspection in NY, but I couldn't justify the added pollution. I didn't notice a bit of difference, except in the exhaust tone.
With the cat off the emissions just go through the roof. Is an extra couple of hp at most worth adding all that junk to the air? I live next door to 10 million people and for me it wasn't.
s5uewf 02-16-2011 04:25 PM
Not to get too far off thread, but cats are not perfect. They also contribute to environmental harm...the U.S. EPA has stated catalytic converters are a significant and growing cause of global warming, because of their release of nitrous oxide (N2O), a greenhouse gas over three hundred times more potent than carbon dioxide.
I think if you remove your cat and get tuned, you'll notice an improvement in power. Likely not too much.
pmason 02-16-2011 05:14 PM
Initially I removed the cat and put in the fabspeed bypass and the M&K 1in1out, also had Steve's chip, but dyno seemed like it gave a few more hp. Sense then I have switched to headers and M&K 2in2out and have Steve reflash the chip, sounds even better.
Icemaster 02-16-2011 05:51 PM
...AND add the M&K - you got a winner. You wont regret it.
Joe Bob 02-16-2011 06:15 PM
Spend a few bucks on GOOD fasteners and they will spin off easily. You can then run leaded fuel if you run hi octane race gas for a DE.
Chip, bypass and sporty muff will be a good improvement. SSIs....the word is...not a big help as with the 3.0.
Wil Ferch 02-16-2011 06:24 PM
For bolts....here's what I say in another thread.....
I've also found that I can use US-thread muffler bolts ( stainless 5/16" x 18 pitch x 1.5" long, along with Silicon-Bronze hex nuts) are *very* close to the stock 8 mm x40 mm steel units that rust up real bad. The Stainless /SiBr combo doesn't gall ( as stainless bolts with nuts might)...and has the added benefit of having a 1/2" head..so standard metric 13 mm tools can be used. This allows easy cat addition / removal during those pesky emissions inspections...and easily allows you to go back to pre-muffler....a serious advantage that SSI's don't enjoy.
Shaun @ Tru6 02-16-2011 06:37 PM
it's a very good idea, but only when matched with a SW chip and an M&K muffler.
Swoboda 02-17-2011 06:25 AM
Is a stock muffler too restrictive compared to a M&K? Is sound the only difference?
hcoles 02-17-2011 06:46 AM
one aspect that might be considered when running without a cat, it saves the cat from wear and tear, it can then be installed for testing if needed in your state or location - I would never consider doing that but it occurred to me.
rusnak 02-17-2011 08:13 AM
And a cat bypass can have a second testing bung installed for an O2 sensor. Do that to the cat, and all of a sudden it's illegal.
DRACO A5OG 02-17-2011 05:24 PM
My 2 cents, I feel the upper end performance, not much at low RPMs.
A side effect may be some back fires on decel, liken to a race car :D
I've installed the M&K Pre Muff (Cat By-Pass) on stock 1 in1 out & SW Chip.
Sound is much more throatier.
Jim
lynn911 03-13-2012 12:32 PM
cat bypass
I replaced my cat with a bypass and SW chip noticed some small gains , I am running a quite open exhaust Straight pipe with a 24" cherry so the noise was an issue, I did not change the mixture.Can some one describe a little better how to adjust the mixture . or is this a Porsche shop job?
I have since gone back to cat till I can work out better noise reduction.
Has any one used the car chemistry baffle plate systems?
Cheers
Autoban 03-13-2012 01:03 PM
I have a stock '86 cab and would like to switch to a cat bypass with a sport exhaust. I live in Virginia. Does anyone know if an '86 Carrera with the 3.2 L needs to pass any emission testing?
vash 03-13-2012 01:05 PM
i have a bypass i would love to get out of my garage.
Arne2 03-13-2012 01:12 PM
Same exact setup on my '84. I bought mine that way, so I can't speak for the "before" and "after" changes. But it does run great and sounds pretty good. Some people complain about exhaust smell w/o the cat, I haven't found that to be too bad. No backfires on mine.
