-   -   Help me interpret this WB o2 reading (http://forums.pelicanparts.com/porsche-911-technical-forum/592230-help-me-interpret-wb-o2-reading.html)
axl911 02-16-2011 11:48 PM
Hi all,
I have this annoying loping idle in my 3.6 which I think is an vacuum leak and is chasing down. I've cleaned/replaced the O2 sensor, MAF, and ISV so these components could be ruled out. Engine also has new cap + rotor. Wires were done not too long ago.
Anyway, I have a wide band O2 that I can move between two heat exchanger header banks before they merge at the cat.
On the left side, I see bouncing AFR from 14.2 to 14.7.
On the right side, I see bouncing AFR from 14.7 to 15.1.
If it is an vacuum leak then the leak would be on the RIGHT side correct?
thanks,
anthony
Bill Verburg 02-17-2011 04:12 AM
Originally Posted by axl911 (Post 5851713)
Hi all,
thanks,
anthony
14.7 is stoichiometric, less than that is rich, more lean. Too much air makes it lean. leak if any is on the right
axl911 02-17-2011 08:28 AM
Thanks Bill.
Do you know what the AFR reading will/should be if I disconnect the O2 sensor and let the car run in open mode?
This is a late 95 US car, so I don't think there is a CO variable setting on the car.
