Senior Member
ohecht's Avatar
Fuel Line O-rings, etc.
Is there a common sealing or O-ring that is used in all the connections on the SC fuel system that are typically disconnected for testing purposes?
i.e., the injectors, supply line to the fuel distributor, WUR, etc.?
I see at least 3 parts listed with Pelican, but I am not sure which ones I need and in what quantities if I want to have some around for after I inspect or test fuel-related components in the future.
Thanks,
Olivier
Olivier Hecht
1982 911SC
Old 02-08-2002, 07:18 PM
Senior Member
Superman's Avatar
Good question. This is where you need the 'parts guys.' They can tell you how many of which things you need. And if you want extras they'll have an idea which ones. Besides, they can't be expensive. Can they?
I have a similar curiosity about the parts I'll need to reassemble this engine. What comes in the top end gasket kit and what doesn't. That kind of stuff.
I know each of my injectors basically take two o-rings, different sizes. There are at least two or three different shaped copper rings in the fuel system.
Mocha 1978 911SC. "Coco"
Old 02-08-2002, 07:32 PM
