911 sc cigarette lighter
So about a month ago, i bought a little 12volt plug in heater and it worked for about a week until the tip of the plug melted/ cracked, im really not sure which. so i just cut it off wired it into the battery
Anyways, i just bought a gps (its more expensive than the 10 dollar heater) and im hesitant to plug it in in fear of the same thing occurring. so i took some pictures of the inside of the cigarette lighter to see if everything was fine before I do. the tab on the right side is bent into the middle, im not sure if it is supposed to be this way or not, but the tab on the left side is not bent, it is straight
any info would be helpful
thanks
scott
'80 911 sc
'96 Range Rover
Old 01-09-2012, 06:05 PM
RETIRED
Joe Bob's Avatar
The SC cig hole is a little bigger than the US standard. I would suggest wiring in a port unde the dash.
2012 ML350 3.0 Turbo Diesel
Old 01-09-2012, 06:31 PM
porwolf's Avatar
The cigarette lighter socket is not designed for heaters. Way too much current draw I think. If your socket still works, still supplies 12V, the GPS should be no problem. Much less current. I also would bend the right side tab back towards the side..
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 01-09-2012, 06:38 PM
I had power in my 83 SC, but could never get anything to work because of the size. Tried a few tricks to no avail, so installed an outlet under the dash beneath the glovebox utilizing a previous hole in bottom of glovebox. Works great and can't be seen.
Old 01-09-2012, 06:45 PM
80-911SC's Avatar
you used to be able to get a sleeve that went in the car and adapted it to the standard size .. I have one in mine .. I'll see if i can get it out and if it has a part number or ?? on it ..
I am sure you could shim it .. its only two connection .. a ground and positive ..
Old 01-09-2012, 09:43 PM
nineball's Avatar
you can also take apart the plug and bend the two pieces of metal on the sides out further so they make good contact with the sides of the holder.
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 01-09-2012, 10:10 PM
alright, thanks for the help everyone
im going to make a run to the dismantler this weekend and grab on off of some old car
until then, ill try to bend that tab back and see if i can get it to work
-scott
btw, i think it still works with a phone charger, ill double check
'80 911 sc
'96 Range Rover
Old 01-10-2012, 04:32 PM
does .87" diameter and 1.18" long sounds like US spec?
New 12V Safety Car/Motorcycle Waterproof Cigarette Lighter Socket Outlet Plug | eBay
thanks
scott
'80 911 sc
'96 Range Rover
Old 01-10-2012, 06:36 PM
Heat sensitive clip pictured, centers and retains lighter element until red hot. Expansion releases. Spring retracts.
Electric tape converts smaller to larger.
12v is 12v
Old 01-10-2012, 08:05 PM
nineball's Avatar
some alternatives that can be mounted anywhere you like:
Marine Grade Cigarette Lighter Socket 12 VDC 265-274
Cigarette Lighter Socket 265-570
Old 01-10-2012, 08:14 PM
