too many projects 1983 sc
post a pic of throttle body
hello,
got my fuel injector seals replaced (1983 sc)...thanks to all that responded. still a little hunting but no leaks at the injectors or runners. i want to replace the vacuum lines on the throttle body as the lines from the dizzy are brittle. when doing a search the diagrams are great but are only diagrams. can anyone either post a pic of the rear of the motor with the vacuum lines hooked up i.e. red and blue etc. i am going to try to replace mine without doing a partial engine drop ...can it be done? are there any tricks to make it easier? pelican no longer has the braided hose so i will use standard vacuum line hose from local parts house. regards and thanks for your help, ben Last edited by 56 nomad; 03-02-2011 at 08:44 AM.. |
evening bump
anybody?? thanks , ben |
