Ultimate 3.0l CIS to MFI conversion thread
The 1974 Carrera RS 3.0 had a 3.0l engine with MFI which by all accounts was a sweet combination. Since there were only 55 of these machines built I suspect that over the years people must have attempted to emulate this engine by starting with a ROW 76/77 Carrera 3.0 or SC 3.0 and converting the CIS to MFI. The purpose of this thread is to store the cumulative wisdom (or folly ;) ) of those that have attempted a conversion from CIS to MFI on a 3.0l engine.
This is not a thread to argue the merits of MFI vs CIS vs EFI vs carbs. There is plenty of information out there on current EFI conversions and much advice on carbs. Just interested in hearing the experiences of those that have done this conversion and what they had to do to make it work. For instance: - Will MFI work adequately with the stock CIS pistons? - What 3.0 parts did you change? Pistons? Heads? Cams? - From what model did you source the MFI parts? - What space cam are you using in the MFI pump? - What gotcha’s are out there? - Perhaps most importantly, now you have done it would you recommend someone else attempt it? SmileWavy Here are some pics to get this thread started. http://forums.pelicanparts.com/uploa...1298605883.jpg http://forums.pelicanparts.com/uploa...1298605897.jpg |
Talk to Jeff Higgins.
CIS pistons will not have the clearance for E, S, 906, RSR, etc. cams. |
I think MFI will certainly work with stock CIS pistons, and the cam limitations imposed by those pistons, but it certainly will not take full advantage of the conversion. MFI, like carbs, opens up the selection of cams beyond those which are CIS compatible. I believe that in order to realize its full potential, any switch from CIS to MFI should be accompanied by a piston and cam change.
With that in mind, I used JE 10.5:1 compression pistons and a custom cam grind from John Dougherty, which he calls his "GT2/102" grind. If you look at the cam spec chart on his site, you will find a "GT2" grind on 112 degree lobe centers. All he did was narrow the centers to 102 degrees. The only other engine modifications were to open up the intake ports to 38mm and to twin plug it. Starting with an early large port 3.0 as a base would negate the need for the port work. My MFI system consists of 2.4 "S" throttle bodies and stacks, along with a 2.4 "T" pump with the "T" space cam. The 36mm throttles and stacks are enough to feed a moderate rpm (up to 7,000 rpm) street motor, but if you want it to spin up higher, it will need bigger throttles, stacks, ports, and cams. Not to mention some lower end improvements (mine has stock SC rods with ARP bolts). Think Carillo or Pauter rods if you want to spin a 3.0 much higher. There are a lot of little details that differ from a CIS motor to an MFI motor. Some of the little pieces are optional, depending on how you would like to supply oil for the MFI pump - its own isolated, self contained supply or recirculating engine oil supply. Some of the "gotcha" details: Fuel pump is different. Scallop in the intake port for the CIS injector needs to be welded over. Hole for MFI injector needs to be drilled and tapped into intake port. Breather cover needs oil return line from MFI pump if recirculating supply is used. There is an oil feed line (to the MFI pump) that goes underneath the oil pressure sender where it screws into the top of the case that is unique to MFI. This is only used for the recirculating oil option. There is an rpm sensor that reads from the distributor that activates a fuel shutoff solenoid on the MFI pump during trailing throttle. Most of us take this system off, and live with a bit of popping and banging on the decel. If you want it to work, you need this sensor. Four bearing cams are larger in diameter than three bearing, so the original MFI drive seal on the front of the left cam will not fit. Use a seal from a turbo oil pump drive or get a custom made seal from Supertec. The tin is different on that left front corner because of the MFI drive. The tin between the upper and lower valve covers on the left side is different; the MFI tin has a steel tube through it that is used to hook up the hoses to the warm-up solenoid on the pump, and a heat take-off tube unique to MFI on the left heat exchanger. Many of us eliminate this system as well, replacing the solenoid with a screw or with one of Supertec's cable actuating systems. The left heat exchanger needs that warm-up take-off tube if you want to run the stock warm-up solenoid. MFI needs a floor throttle to keep it running before it gets warmed up. CIS cars don't have this. The car will run without one, but it really is a lot nicer to have as it's warming up. Without a floor throttle, you will need to keep it running yourself, with your right foot, while it warms up. There is a thermal time switch that activates a bypass solenoid on top of the fuel filter console to prime the motor when cold. Many of us eliminate this thermal time switch and simply wire a momentary contact pushbutton switch mounted in the dash to give us direct control over when and how much the motor gets primed. Speaking of the fuel filter console, it is unique to MFI. The CIS one won't work. That's it off the top of my head. Like so many things, "the devil is in the details". None of the MFI unique stuff is particularly hard to find or expensive, but it will slow things down if you find out too late you need it. Best to gather up all of the odds and ends before you even start. I hope my list helps with that. Would I do it again? Would I recommend it to others? Hell yeah - the difference is truly astonishing. The throttle response, the sound, the added power, and the cool factor definitely made it all worthwhile for me. |
Thanks Jeff... :mad: Just when I was happy with the way my SC has been running you post something like this... :mad:
:rolleyes: |
I might have to disagree about the MFI stuff being hard to find and expensive. I can think of a few pieces that are...:(
Here is a 3.0 MFI engine that giovanni86 is building for his '74 Carrera 3.0 RS clone:
http://forums.pelicanparts.com/porsche-911-technical-forum/585431-74-rs-3-0-clone.html Details are: SC case Mahle high compression pistons and cylinders SC heads 3.0 RSR camshafts MFI from a 2.4 throttle bodies modified (bored out?) to '74 Grp 4 specs Interestingly engines built like this are granted FIA approval as RS 3.0 equivalent. |
Jeff, thanks for the details on your engine. I have watched your track video and it sounds fantastic. Did you keep the SC distributor? If so did it need to be recurved?
I started with an SC distributor that I had re-curved by Barry Hershon. It was set up for full advance to come in at 2,500 rpm, so it was effectively running full advance all the time, only retarding to help it idle. That was the first iteration of the motor, when it was single plugged. I'm now running twin plugs, lit by an Electromotive crank fired ignition. Five degrees initial advance and 25 total.
Flieger, I've admittedly been out of touch on current prices for MFI gear - I squirreled away a bunch of it before everyone wanted it again. What pieces are getting expensive? I still think a guy can piece a setup together for far less than the cost of PMO's or any of the newer EFI systems. Granted, more expensive than Webbers, but not much. Or am I woefully out of touch (as usual...)? |
The MFI injection pumps are rather expensive. And the fuel pumps. Expensive for my budget anyway ! But from my experience MFI is worth it.
The electric fuel pumps are $500 plus unless you have a core.
RPM transducers seem to be harder to find. The injection pumps in goo condition fetch a pretty penny. Good throttle bodies are worth a lot, as well. Most of the used stuff is out of spec, so the good stuff is getting harder and harder to find. And the guys who can tune or rebuild them are getting fewer and fewer, it seems. |
I think I paid $500 to have a pump rebuilt a couple years ago. At least at the time new ones were NLA. But you can use an aftermarket pump at a fraction of the price. |
thanks to Jeff Higgins
The $600 new ones from Porsche are made in China, so I would rather go with a rebuilt German Bosch unit. |
Nice thread,,,
I remember a guy here in the mid-Atlantic area who was playing with MFI on 3.0 Ltr motors way back in the mid 90s. Yes, when the parts were more reasonable and there was more of the stuff floating around. |
I think Zim's still rebuilds the fuel pumps for something like $300-$400.
It's actually not all that hard to do yourself. I started a thread on how to do it a year or two ago when we needed one for my youngest son's 912 to 911 conversion. If it needs brushes and to have the commutator turned, any auto electric place can do that. If it leaks, replacing the o-rings isn't all that hard. |
The problem was the brushes had worn down through the commutator into the shaft.
The little trooper kept on going until the bitter end. You have to love that German craftsmanship. They certainly do not make them like they used to. If you have a rebuildable core, it is not so bad, but if you are converting to MFI or your core is not rebuildable, then it gets more expensive. |
I wonder - could the MFI specific pump housing end be grafted onto a carb or CIS fuel pump? Or could the armature from a carb or CIS pump be used to replace one in an MFI pump? Do the electric motors run at different rpm's, or are they physically different sizes, or anything like that that would preclude making such a "frankenpump"?
The standard CIS fuel pumps are adequate, set to 14psi with a PMO fuel pressure regulator.
Or you could use a few of the Bosch aftermarket pumps, the "044 Motorsport" pump comes to mind...I think it is <$200 Mark Jung tested some of the cheap pumps that say they work for MFI, and they did not have enough flow (although high enough pressure for low flow) |
Mallory makes some nice pumps for drag racing that should work, bu would have to be regulated and they cheap, but still cheaper than Bosch.
Just went to the PMO site to look at their pressure regulators and saw they also offer MFI throttle bodies that appear to have the MFI injector in the throttle body which would avoid having to get the injector hole drilled in the heads. Am I right in assuming this? Would save some $'s if that is true. Here is a pic from the PMO site:
http://forums.pelicanparts.com/uploa...1298819655.jpg |
Hello everyone.
Kiwiokie just invited me onto this thread because he spotted a 77 3.0 Carrera on another thread that I converted to MFI. First Kiwiokie, that set up you just posted from the PMO set up is a completely differant ball game. I think the idea is to deal with Porsche parts to duplicate the 74 3.0 RS. After reading the thread, Jeff Higgins has pretty much covered it. And yes, 69-73 MFI parts are becoming harder to find. There are out there, but the price is higher than the old days. My only disagreement with Jeff is the possible use of CIS pistons. I wouldn't even try it. My approach was to copy the MFI system from a 71-73 MFI car and build it into my engine. I started by installing J&E 9.5:1 pistons the 69-73 911S MFI cams. I used the 69-73 cams housings so in would be less hassle down the road. I 'd hate to be stuck looking for a custom seal if needed. I saw a set of mag housing throttle bodies and stacks from a 69-71 car here on Pelican. They were already bored for a abandoned 3.0 RS project. I sent them to Eurometrix to be rebuilt and double checked. The bore matched the port size of the 3.0 carrera. (same as early SC). I then sent a used 2.4 liter pump to Gus and told him to build me a 3.0 RS pump.($1600). I think I used a distributor from a 2.7 RS. To make it simple, I built a 2.7 RS engine onto a 3.0 aluminum case. (original engine to the car.) SSI heater boxes and stock muffler. The most important issue was drivability. I didn't want a high strung finiky running engine. The engine came out better that expected. No bugs to work out, and it ran stronger that anything I've ever driven in the same class. It had to have 250 HP. I forgot the heads. I build a jig to bolt the head to, and bored and threaded a MFI port into the head. I didn't weld up the cut out for the old CIS injector. If you want Kiwiokie, you can paste a photo of the engine from the other thread. It's beyond my capability. As far as cold start, I used the 69-71 air cleaner with the squirter tubes built into the top of it. Except for the J&E pistons,every part is from a 69-73 MFI car. |
3.0rs mfi
I've now got Rick's '77 C3.0, with the engine that he describes above, shown in the picture below. He did a beautiful job on it, cosmetically and mechanically.
It only had about 1,000km on it when I bought it, so I'm still kinda running it in at 5,000km now. I expect to dyno tune it soon, and will report results here. The engine pulls very smoothly, and seat of the pants says the engine is more than 11% stronger (capacity differential) than my rebuilt 2.7RS-spec MFI, 9.8 compression Mahle P/C engine. We can't quite get the 3.0 to idle as smooth as the 2.7, however. Given that Rick did everything fresh and right - Matt Blast on the t-bodies and stacks, Gus on the pump, S cams, etc. - it's not clear to me why we can't get it quite as smooth yet. The A/F readout on the dyno will be helpful there. Also, in trying to better understand the original Porsche 3.0RS set-up for comparison, I've corresponded with Matt Blast at Eurometrix and Aaron Hatz at Flat 6 (he has rebuilt at least one original 3.0RS). Both believe that the 3.0RS intake set-up was pure 2.7RS - 36mm intake ports, 312 plastic stacks, S/RS T-body specs, S cams, RS space-cam, etc. Porsche reported the 3.0 hp at 230 at 9.8 compression, vs. 210 and 8.5 for the 2.7. I have to believe there is more than +20hp, however. Having been disappointed with the leak issues of a magnesium case (even with all the case work done), and experienced the power and torque differential, I'm a real fan of the 3.0MFI. But I still have a stock '78SC 3.0 in a DE car, so am interested in hearing about others' experiences with more aggressive 3.0MFI engines. Best, Bob http://forums.pelicanparts.com/uploa...1299078724.jpg |
Bob, I thought that car idled like a kitten.
question: My mechanic ask 5K euros (more or less 6.5K usd) to use the rsr cams instead of the s ones and for use the modified stacks instead of the plastic ones... do you think the price differencial is "fair"? I'm planning to use my car both in track days events and for "compatible" road use(compatible=country road..), do you think that upgrades are worth for me? thanks |
what is the fair price for a pair of plastic stacks and for a pair of s cams?
Rick, it seems to idle a little low and hunts moderately, and is a little rougher cold than the 2.7. We're at about 1,000 feet here, and honestly I can't tell you if my mechanic here (well versed in MFI) set it up much differently in the tune up than you - I know he tried a click leaner but put it back where you had it on the pump. It appears to idle richer than the 2.7RS - Gus redid that pump as well - but I haven't tested the A/F on either yet. I've got one of Henry Schmidt's manual MFI enrichment controls on the 2.7MFI, and always lower it as quickly as possible - I'm thinking of putting one on the 3.0 to see if that makes a difference.
But once I get above 3,000 rpm, there's no question which engine is in the back! BTW, do you recall if Gus used the 2.7RS MFI pump space cam, or something different? I know it's marked 3.0RS by hand on the pump. Are you still finishing the Talbot car, or on to something else? Need a place to stay on your way to Savannah this year? Bob http://forums.pelicanparts.com/uploa...1299085409.jpg |
Giovanni, others will know better but $6,500 seems quite a bit for different cams and bored stacks vs. S equipment. Lots of different, high quality aftermarket cams to choose from, I think mostly in the $1,000 +/- range. Plastic S stacks are $600-$1,000 I believe, based on condition.
Thanks Bob and Rick, very useful info. That engine is beautiful.
That's Gus's writing on the pump. I'm sure he used a 2.7 space cam. Still on the talbot car. Should be done it April.
thanks EmeraldE
does anyone knows if it is possible to convert an early bosch pump to a 019 type?
thanks |
Any 2.4 pump can be converted to 019 specs. exactly - 015 911T, 014 911E, 013/021 911S
The others can be made to that spec. but a 2.4 L pump is recommended to start with |
Great pics sluk. Do you have the details of the pump - model number and space cam?
| All times are GMT -8. The time now is 09:25 AM. |
