RETIRED
Joe Bob's Avatar
Source for heat shrink wrap in bulk?
I don't want to buy a "kit" with useless sizes and I'd like to cut to the length I want, not someone else's idea of what I want.
Mostly small gauge from LED wiring up 10-12 gauge.
Anyone have a source?
EDIT:
Sorry should have put this in off topic....
2012 ML350 3.0 Turbo Diesel
Old 02-25-2011, 02:08 PM
abit off center
cgarr's Avatar
McMaster Carr has about anything you could want!
McMaster-Carr
______________________
Craig
G2Performance
Old 02-25-2011, 02:16 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Waytek wire is a great place for bullk electrical stuff.
Waytek Inc, Home page to buy fuses, circuit breakers, cable ties, wire and other electrical supplies By Waytek Inc.
Great online catalog.
(can't bellieve Craig stole my favorite place to link........ )
Kevin L
'86 Carrera "Larry"
Old 02-25-2011, 02:59 PM
David's Avatar
If you live in or near a big city there should be an electronics store (not Radio Shack) that has heat shrink tubing in 3 ft lengths in all sizes. You'll know it when you get there because there will be more nerds than you've ever seen in one place.
Old 02-25-2011, 05:12 PM
Peter Zimmermann's Avatar
In Bakersfield my only option (recently) was Harbor Freight. I was able to buy four sizes in rolls, but the small size for single strands of automotive wire was green. Oh, well...
Everyone else (Pep Boys, AutoZone, Car Quest, Napa, etc.) has a silly selection, in a bag, of 5" long pieces, which did me no good at all.
Keep the Shiny Side UP!
Pete Z.
Old 02-25-2011, 05:27 PM
RETIRED
Joe Bob's Avatar
Thanks, just used up all my small sized wrap wiring in LEDs for my back up lights.....
Old 02-25-2011, 05:48 PM
LJ851's Avatar
^ Nice! Do they put enough light out to be effective?
Old 02-25-2011, 05:58 PM
RETIRED
Joe Bob's Avatar
Right behind me, they are quite bright.....not so much to the sides. Four on each side. In keeping with the light weight of the "R" type lenses. I've been told that if I rough up the bulbs with emery paper they would be more visible from the sides.....don't see the need.
DOT regs say that back up lights "can" be yellow, but with my luck I'd have some Rambo de Nimrod that didn't get the memo. To have back lights inside the lenses, I would have had to replace the amber/red and purchase a set of 1/2 white 1/2 amber lenses, rewire the full red receptacle to take LEDs for brake/running lights.
Cheap fix and I'm lazy....
Old 02-25-2011, 06:13 PM
You should check OSH and/or Home Depot. Both now carry rolls of heatshrink in 3-4 different diameters (I think they're about 4 ft long).
Old 02-25-2011, 06:33 PM
Danny_Ocean's Avatar
That's what I tell folks when they're looking for the local PCA meets...
EBay currently has 2600+ auctions/buy-it-nows for heat-shrink tubing in every imagineable size/color/length:
heat shrink tubing -gun items - Get great deals on Business Industrial, Electronics items on eBay.com!
Old 02-25-2011, 07:33 PM
Canyon Runner
70SC's Avatar
Porsche Crest Heat shrink
Hi Mike , R.S. They carry it. You know, the generic electronics store, Radio ..... How much do u need 100's-1000's or 10-100's
Old 02-25-2011, 07:57 PM
These guys sell small spools
The Shrinkshop
Old 02-25-2011, 08:40 PM
Originally Posted by KTL View Post
dual wall waytek is about the best i've ever seen for cars. Ancor marine grade is a different animal. It's plenty strong and very durable
if i'm doing a harness i'll shape it out first then artistically shoot the gun to maintain its shape. Sometimes i'll only reduce its diameter without completely closing it on the wires. It's as close to a factory look as you're gonna find
i bought a bunch of 4' in various sizes after i checked out a small order
waytek also has 75 amp relays in case you're into very heavy duty instead of the 20-30 amp small cubes. The 75s are common on emergency rigs
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-25-2011, 10:05 PM
fastfredracing's Avatar
I use a shop supply company called WINZER . They have everything. They sell it by spool.
No left turn un stoned
Old 02-25-2011, 11:42 PM
300hp 1800lbs is the goal
pksystems's Avatar
Princess Auto in Canada
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 02-26-2011, 12:02 AM
