-   -   Tach has irregular readings (http://forums.pelicanparts.com/porsche-911-technical-forum/594147-tach-has-irregular-readings.html)
Marko911/944 02-27-2011 12:59 PM
My 83' 911sc cab has a lopping idle and a crazy inconsistent tach reading. When I get it on the road it has trouble revving to mid range. it starts missing, and only runs smooth at idle. Any ideas? I once hooked up a quick start battery charger to the wrong terminals, did I jack up anything specific?:(
j911brick 02-27-2011 01:30 PM
Just based on what you have mentioned, sounds like the two problems are related and probably and ignition issue.
