Pierburg installation w/PMO's
Can the Pierburg pump generate enough pressure with the return fuel line going back to the fuel tank? I am still trying to get the beast up and running. Before I replace everything under the sun, I'd like to make sure that I'm getting 3.5psi to the carbs. I have the old non adjustable regulator from PMO...
Sherwood |
I just put a Pierburg on my car w/o a return line. Works fine with my 46 PMO's. Should be able to just end at carbs if you want to.
1997 C4S stock...ish 1970 911T Restored Hot Rod....Sold ![]() http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html |
I appreciate the responses, it's been challenging to get the beast
back up and running....Tim |
