2nd that........where did you get the brace?
Thankx, I did.
Probably more bling than function. Welded on the brackets when the car was stripped, then added the bars once it was together. |
Start it in the evening with the engine compartment open and look for little blue electrical discharges around the MSD connections especially at the coil connection.
your carbs may be dirty if you're using routine 10 micron fuel filters
a Racor with 2 micron filters is trick |
| All times are GMT -8. The time now is 01:22 AM. |
