SLR SLR is offline
SLR
heater blower
Wearied stuff !
I pulled the blower off because of the hideous noise it was making. All turned smooth and no play in the shaft took the shroud off then put 12v across the turninals the thing spun up ok with no screeching cool. all back together, self healing car.
thanks for the replys.
Thanks Steve.
Old 03-04-2011, 01:00 PM
ghamilton's Avatar
Hope you at least put some lithium grease on the bushings before you re-installed?
G. Hamilton
'82 SC Guards Red-2nd time owned-Now sold
"Bumerang"
'70 TR6
N of Boston
Old 03-04-2011, 06:27 PM
heater blower
What did you have to do to get the blower out?
Old 03-06-2011, 03:00 PM
You need to let us know what year/car you have to get a useful answer.
Most, just disconnect the 2-3 hoses/ducts and a couple screws and unplug it.
Get a Bentley Manual for your car.
Old 03-06-2011, 05:05 PM
dshepp806's Avatar
It will return.....
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 03-06-2011, 08:04 PM
SLR SLR is offline
SLR
Getting the blower out is a bit fidley but not hard.
first I took off the hard plastic houses unplug the terminal
then there are 3 nuts that hold the motor down. the hole
thing comes out, I undid the screws on the duct that runs out of
the fan housing, but no need to do that. it all works well now,
I went out for a drive Sunday with the heater running all still fine.
It looks that the blower motor can be completely re built, my Porsche
parts guy only wanted to sell me a new unit.
My car is 85 euro.
Thanks Steve.
Old 03-07-2011, 12:31 AM
Classic's Avatar
New bearing will set you back about 75 cents when, if it goes again
Classic 1969 911T
Old 03-07-2011, 01:45 AM
How bout for a 69 E?
Old 03-07-2011, 07:23 AM
SLR SLR is offline
SLR
I recon if you can do it to one you must be able to do to an other,
After all it is only an electric motor.
Old 03-07-2011, 07:47 AM
