-   -   Battery isolation switch (http://forums.pelicanparts.com/porsche-911-technical-forum/594925-battery-isolation-switch.html)
imoto 03-03-2011 06:42 PM
In a street car where have some of you guys mounted a battery isolation switch ? Photos would be good.
Cheers;)
DRACO A5OG 03-03-2011 08:23 PM
Well, if you mean to kill the car, 84-89, we just pull off the DME relay.
If you mean to work on the car and "isolate the battery", at the negative side battery terminal, a $8-12 dollar part.
http://www.pelicanparts.com/cgi-bin/...off_switch.jpg
imoto 03-03-2011 11:07 PM
DRACO I have an 81 no DME relay on the vehicle, the battery terminal you show is a good idea it really is as you say to" kill" the power when doing elec jobs.
I thought of using a Hella switch with a key but the terminal is simple the key I guess would add an anti theft element.
Thanks for your reply
DRACO A5OG 03-03-2011 11:32 PM
So will the Negative Battery Terminal device. My buddy turns his baby off all the time. with the fuse it keeps the radio stations, I think?
Joe Bob 03-04-2011 05:47 AM
I use brass marine battery terminals with wing nuts. Cuts down on corrosion.
Unless you have a separate battery backup your radio presets are wiped when the negative is pulled.
RoninLB 03-04-2011 06:43 AM
I use Ancor marine lead negative with the wing nut disconnect @ $5.50. A rubber cap is also available
Lead Battery Terminals Negative With 5/16" Posthttp://forums.pelicanparts.com/uploa...1299248981.jpg
West Marine also has tinned copper and gold plated terminals. Marine grade costs a few cents more than auto store parts but it has to be high quality to survive in extreme conditions
i never took apart one of those switches but anytime you have a switch or connector you introduce voltage drop. A switch is more prone to have a higher drop. I can only guess that the switch uses a springed connector instead of having a solid connection by using the wing nut. I drilled a hole in a wing for an easy recovery string as it's easy to drop it into the dark regions.
different strokes... etc
m1franck 03-04-2011 10:48 AM
Mine is mounted like this
http://forums.pelicanparts.com/uploa...1299264451.jpg
http://forums.pelicanparts.com/uploa...1299264491.jpg
80-911SC 03-04-2011 06:01 PM
Show off ........
But a very clean install ..... I guess i'd show it off also .......
m1franck 03-04-2011 06:07 PM
Just wanted to show what you can do with lots of time and little common sense!
PCA7GGR 03-04-2011 06:27 PM
Here's what I did with a bit less money:
http://forums.pelicanparts.com/uploa...1299292030.jpg
ben parrish 03-05-2011 04:51 AM
Sergio, do you have a kill switch on the positive lead or is that a solenoid for something?
Fritz Peyerl 03-05-2011 05:32 AM
Battery cut off switch
On my 912 I mounted the switch in the trunk and the key is above the pedal cluster.
That way I can easy cut off power when I park the car over night during my travels.http://forums.pelicanparts.com/uploa...1299331658.jpg
http://forums.pelicanparts.com/uploa...1299331674.jpg
http://forums.pelicanparts.com/uploa...1299331690.jpg
http://forums.pelicanparts.com/uploa...1299331710.jpg
http://forums.pelicanparts.com/uploa...1299331743.jpg
imoto 03-07-2011 03:07 PM
Originally Posted by Fritz Peyerl (Post 5883156)
Something like this is what I had in mind..dont have to open the front when using as anti theft, also as great as they are the relocated batteries into the old aircon evap smugglers box location is not possible on a RHD vehicle, the smugglers box is small only gives access to the steering column connection to the rack.
