ignition wiring
Good day,
In the process of rebuilding my 1971 E engine and I need to rewire the ignition. It's been awhile since I took it apart and the ink on the little tags has worn off. Go figure.
I have the following wires coming out of the Motorola ignition box: 1. green with a female spade terminal, 2. black with a round terminal, 3. blue, with a round terminal and a dust cover.
There's also 4. a red wire but that one is easy. (has remained plugged to the juice on the relay board)
Finally, 5. a dirty gray/cream wire that I found, that was cut a couple of inches away from the box, by some PO.
Any help in figuring where the various wires go on the distributor, coil or elsewhere would be welcome. The wire colors don't seem to match up exactly with the diagrams elsewhere on the site and I don't want to fry the box !
Thanks.
Michel
Old 02-10-2002, 05:53 PM
