what kind of seat do I have and...
newbie....The electric controls dont work - any idea what the problem might be?? Thank you in advance
Old 03-05-2011, 08:24 AM
76 911S Targa
Fuses? Loose connector under the seat?
Old 03-05-2011, 08:59 AM
smshirk's Avatar
partial power comfort and likely the switches are bad. Sometimes you can clean the contacts but there is a good chance the parts will fly out everywhere when you take it apart.
2001 Boxster S 3.6, 94 968 Cab, 80 911 Weissach Edition, 2003 E46 M3 and still looking for the SC in my avatar.
Old 03-05-2011, 10:20 AM
Almost always crudded up contacts within the switch mechanism. Have brought quite a few "back-to-life" by running a strip of emery paper under the partially-hidden contacts.
Getting the switch out is a bit of a pain, especially if you care enough not to cut wires. A search here will show plenty....but in most cases its the contacts being a bit corroded or crudded is the core problem. Check easy stuff like fuses first.
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 03-06-2011, 11:16 AM
