tbitz's Avatar
soundproofing, should I even bother?
I have the engine out and have removed all the soundproofing which was deteriating badly.
I looked through the archives and read that putting the soundproofing pad doesn't seem to reduce noise by much.
What is peoples opinoin on this. Should I put a soundpad? (I do have a Targa which has lot's of noise to begin with).
Should I use the stock material, Dynamat, B-quite material, or nothing?
Here are links to the above suppliers:
http://www.dynamat.com/
http://www.b-quiet.com/
Cheers,
Tony
'78 911SC with BITZRACING EFI conversion kit
Old 02-10-2002, 08:20 PM
Hilbilly Deluxe
emcon5's Avatar
My vote is for nothing. I installed the factory pad when I had my engine out for a clutch job back in December. There was no pad there before, and I can't tell a difference in sound. Waste of money, and adds weight.
Tom
82 911SC Coupe
GTI Cup #43
Old 02-10-2002, 08:28 PM
tobluforu's Avatar
I sprayed undercoating after I removed mine. Looks great!
Old 02-10-2002, 08:29 PM
Funny you should bring it up; I removed the sound pad on my car yesterday and painted the firewall with POR15 Chassis paint.
The verdict? Almost no difference in engine noise, with SSI's and SS Burschoff exhaust.
Paul
1969 Porsche 911T 3.2 (Matching # engine safely in storage)
2021 AMG C43
2020 BMW X4
1979 Californian Moke
Old 02-10-2002, 08:45 PM
I used Dynomat on the entire floorpan, rear deck, and doors of my 73. I haven't really driven the car much yet, but I do know that the doors shut with a high quality "thump" now. I would recommend using dynomat on the entire rear deck and doors, but I don't think that covering the rest of the floor will do much for you.
Bill
William Armentrout
1973 911T
2.7 carerra rs specs
Old 02-11-2002, 03:38 AM
Cool
Sound deadning is another "personal opnion" answer. I did interior floor pan, firewall, doors, outside trans. tunnel, and engine comp. with the Dynamat [their top model] and love it. Reduced road, trans. gear, and most harmonics resonating thru the car. Engine and exhaust noise sounds cleaner without a hollow beer can sound overhang. Again, this is a personal opnion.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-11-2002, 06:28 AM
I was in the process of putting a new one in my car. So while the old one was out I figured I'd drive it around and see if I noticed any difference without it.
I really couldn't tell much difference. A tiny bit, maybe. But that may be just because I knew it wasn't there.
I reinstalled the new one because I had bought it already and it was easier than removing all the old glue and refinishing the firewall.
Old 02-11-2002, 08:03 AM
andyu911's Avatar
After I removed that falling-apart soundproof pad, I was happier ever after. Can't tell any different. I would never bother to put another one.
Andy
'87 Carrera
Old 02-11-2002, 10:45 AM
davis911s's Avatar
I agree it really is a personal thing. BUT all that Dynamat is heavy, so if the noise isn't too bad, then the weight issue might sway you. I will not replace mine when I take it out.
Shawn
Shawn
77 Targa with 2.7
My never-ending work in progress that has been off the road since Mar 2004
Old 02-11-2002, 10:46 AM
Cool
Shawn....I agree with you on weight of Dynamat. I probably added enough weight to outweight the weight of completely removing yhe AC system. I may spend all day in the 911, weeks at a time, and it makes a difference to me. Harmonics and driver fatigue are related IMHO.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-11-2002, 10:56 AM
tbitz's Avatar
Thanks for the input guys.
Looks like soundproofing is a waste of time, money, and weight. I will not replace mine.
Tony
Old 02-11-2002, 12:08 PM
Registered Loser
My car has no factory sound proofing...and it is a targa...so I covered the whole engine area with Dynamat Extreme and added more to the doors. Then I put down extra floor mats - 2 or 3 both front and rear on both sides of the car. The verdict: Probably added tons of weight but the car is *much* quieter and everyone who rides in it mentions the difference.
Owner of a wrecked 944
Old 02-11-2002, 01:09 PM
Student of the obvious
LeeH's Avatar
Without removing the engine, what's the best way to remove the leftover adhesive after removing the pad?
Old 02-11-2002, 01:22 PM
I took the pad out of my 914, and there was adhesive left on the firewall.
It took me a long, long time to get it all off. The best thing that I found was a product called "Goof Off."
Because the paint under there isn't really great to start with, I ended up repainting the firewall.
It looked great afterwards, but it was a ton of work. And that was with the engine OUT of the car.
I didn't want to go through that again, which is the main reason why I replaced my crumbling pad with a new one.
Old 02-11-2002, 01:47 PM
