Help identify electrical component
Hello, after getting my engine all back together (new valve guides) I am working out some electrical difficulties. Could someone help identify this part and it's function? It resides in the trunk (luggage) against the firewall on the drivers side.
http://www.pelicanparts.com/ultimate...ds/relay 1.jpg Since I got everything back together this unit emits a humming/buzzing sound when ignition switch turned to number 1 or 2 position. I have some other electrical issues as well and I wonder if this new sound is related or not. Thanks ------------------ Matt Macpherson 1975 911 S nvalve@yahoo.com |
it is the " seat belt interlock relay" used for 1974-75
Seat belt interlock relay!
------------------ Warren Hall 1973 911S Targa |
Thank You!
cut the C and 50 wires and attach them together to bypass the relay. these relays keep the starter from working until you buckle up, and can leave you stranded, buckled or not.
| All times are GMT -8. The time now is 04:56 PM. |
