Rennch on YouTube
Brace Yourself...
Hi.
I've just taken on this swiss cheese project to restore to a solid body...which weirdly seems fun to me. I need to brace the chassis since I'm going to be cutting off a LOT of stuff. My inital thought is a door brace from latch to hinge panel (maybe triangulated?) but I'm curious where else you'd brace the chassis? I have 20' of 1" square tubing, but can get more if I need. Order of operations (I think) are going to be longitudinal/spring plate area, then inner rockers, then floors, then outer rockers, then front end, then everything else. Here are some pics. As I said...brace yourself. I will do an official build thread on it, as well as document the whole thing on the rennch youtube channel.
Michael O'Neal - 69 RSR Clone(ish) - The build: http://bit.ly/69porschersr 69 911S Blasphemy Build on YouTube Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/ |
You are a brave man for taking that one on...
Best of luck! Tom
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
Red Line Service
Why don't you just "Re-tub" it?
Marc Bixen/Red Line Service West Los Angeles, Ca. www.redlneservice.net / info@redlineservice.net Podcast:"Marc Bixen Live" https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA |
Rennch on YouTube
Because it's meaningful to the owner. And not as fun.
A Celette bench is your new best friend.
Tru6 Restoration & Design |
To keep costs down I would get a tram gauge and check the square-ness, correctness, of the body. See that it's not bent. Then bolt or temporarily weld in a few diagonals under the car.
That way you can cut and chop bits out to your heart's delight. |
Rennch on YouTube
Thus bringing us back to the original question. Weld where?
Rennch on YouTube
Ye of little faith.
Registered Minimalist
Dang. On the bright side, you're going to get a lot of practice improving your metal working skills.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
I don't think there is anything there to work/weld with that will result in any kind structural rigidity.
1986 Targa Guards Red 2021 MT09 SP |
Woooh, not a project I would attempt. I would call the sheet metal a sky-light.
In all seriousness, this is the most constructive comment so far. I've been debating w/myself (which is great because I win either way!) on whether to wade further in w/a response to your photos. I've hesitated because I don't want to squash the dream or your enthusiasm w/a response that will likely be tossed aside - because it's not like Celette benches grow on trees! However, because of the extent of the rust/rot on that tub, especially around pretty much every KEY point including the rear torsion/torque tube, a Celette really is the best option. I have nothing but applause and respect for anyone taking on a project that extensive, but one thing I really don't like to see is someone putting that much time, energy and $$ into something that has only a small chance of success. That sounds more harsh than I intend it to be, but it's REALLY important that the tub is square and straight when you're finished! Stack the deck in your favor!! You've taken on some significantly difficult tasks, you deserve to work with proper tools to get the job done correctly! If someone is paying you to do that work, they deserve a straight, rust-free tub when you are finished. Regardless, I wish you the best on the project.
Are there any mounting points remaining that a celette can mount to?
When welders became affordable for the masses it put us all in great danger. Not sure what the hell is going on in that yellow circle.
Runge Eleven
Any pics of the full car? Would be interesting to see the whole picture...
How would you even save this car?
1982 911SC |
I think pound for pound you'll be adding more new than old, that being said please update this thread as often as you can. I love this type of total resurrection work.
