-   -   MC feeder brake line replacement? (http://forums.pelicanparts.com/porsche-911-technical-forum/59636-mc-feeder-brake-line-replacement.html)
katigbr 02-11-2002 04:55 PM
Just wanted to verify something with the group.
As part of my 930 brake upgrade on my 72T, I've changed my master cylinder to 23mm. The problem is the change in location of the MC feeder line inlet location and the hard (plastic/polyvinyl?) lines used to feed brake fluid from the reservoir to the mc. The angle of the bend needed to clear the steering rack and enter the footwell does not allow the inlet pipe and rubber pipe seal to seat correctly.
I used a 45 degree bend (provided by ate) and used more flexible clear vinyl tubing to connect the new inlet connection to the a section of the old polyvinyl tubing cutoff at a convenient location. I used hose clamps at both ends to seal the connections tightly. I don't think that I have to worry about pressure as it is primarily gravity fed and "pulled" in by the MC action.
Will I have a problem with the vinyl tubing related to brake fluid incompatibility causing deterioration or contamination of the brake fluid?
Anybody been there done that?
Rick
Bill Verburg 02-11-2002 06:37 PM
Depends on the tube material I made a similar extension on mine, no problem. You will also need to relocate the stoplight switch(at least I did) and a longer rod(included in the kit if you bought an up grade kit)
katigbr 02-12-2002 05:18 AM
Bill,
Thanks for the reply. I guess the replacement tubing I used might work.
The stop light switch looks to be okay on my 72. It is activated when the pressure applied by a flat washer at the top of the mc shaft is released during pedal application.
The "kit" did not include a longer rod and I will have to fabricate a longer one. I noticed that there is a 1/4 or 1/2 inch of extra length I need to add when I finished the install. I'll probably just use a threaded rod or bolt cut to the appropriate length. The old shaft ended cone-shaped with a 6-8mm ball at the end. I don't think I need to replicate that due to my non-Porsche master cylinder replacement. I'm assuming that it mated to a cup in the old mc and spread the load. Do I need to create a ball-end on my "replacement" shaft to diffuse the pressure on the mc plunger? It doesn't sound like a bad idea.
Rick
Rick
Bill Verburg 02-14-2002 07:18 PM
Just for future reference, the reservoir tube is available from Ate in a 5 m roll Ate#02.358-0005.5
stcan 10-31-2023 01:39 PM
What's tube are currently available?
PeteKz 10-31-2023 11:44 PM
Do we have a new record for the oldest thread revival?
Matt at Pelican Parts 11-02-2023 04:50 PM
Bill is still active so we may get an answer too!
