Luggage compartment light switch
I'd like to leave the luggage compartment open on my 78 SC from time to time without having to disconnect the wires to the light. Has anyone found something like an inline switch or other method of being able to turn off the light with the lid open? Thanks. Dick
Old 03-10-2011, 07:18 PM
RETIRED
Joe Bob's Avatar
Pull the fuse, tape down the contact or install a thumb switch.
2012 ML350 3.0 Turbo Diesel
Old 03-10-2011, 07:41 PM
Try putting a styrofoam cup or something like that under the switch plunger. That way you can turn the light off, but if you forget and slam the hood down, you won't really break anything.
Old 03-10-2011, 07:46 PM
Jeepers....Styrofoam cup?....pull connectors?.....
Here's what you can do, install a nice 0/1 labeled, on-off switch in the rear trunk panel board. Splices right in using stock connectors, no cutting, looks factory. It allows either the plunger switch to operate as normal, or it de-activates the plunger circuit.--->
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 03-11-2011, 04:59 AM
i installed a switch
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-11-2011, 05:17 AM
Recreational User
porschenut's Avatar
Easiest way is just pull the light bulb out and put it back in when you're done.
Old 03-11-2011, 05:54 AM
I like my styrofoam cup more.
Old 03-11-2011, 06:04 AM
not really, isn't the bulb behind a lens? held in by 2 screws? that all falls apart when the screws are removed?
OT: ------> *Wil* "Ferch" ....... "who" *makes* that ''tower '' +bar+ ?*?*
Bob S
Old 03-11-2011, 06:35 AM
I made the tower bar...as a modified and improved version of an earlier Rennline piece.
I am surprised at the acceptance of "kludge" fixes like this for a "Porsche".....but then again, I see broom sticks holding up lids on $400k 935's.....so it goes. Pulling a bulb is "easier" than flipping a switch?? I agree about the screws and such making it that more diffucult......
I was answering the OP's question....yes, better things can be done like installing an inline switch, and it can also be made to look factory without any serious effort.
Wil Ferch
Old 03-11-2011, 06:41 AM
I appreciate the suggestions. Will, I really like the switch and placement. I think I'll do exactly that. Thanks for the idea.
Dick
Old 03-11-2011, 07:37 AM
Easy Peesy. Go to your FLAPS...and find a switch like this...basic rocker. I like the O/1 as it does not say "on/off" in English...can be taken as "factory. Drill a hole in the cardboard trunk panel ...insert...and attach wires that normalyl pulg-into themselves. If you trace the light you will easily see the "plug" where they attach to one another. Disconnect and plug into the switch spades instead. I forgot details but maybe you need to crimp a male or female spade to the switch to allow the factory plugs to work. Totally reversible ( although I can't imagine why).
Make sure you update the Xerox copy of your factory wiring dieagram that you *do* have for *your* car, to show the change .....right ?....
Wil Ferch
Old 03-11-2011, 08:48 AM
Recreational User
porschenut's Avatar
Oh, brother. No, it doesn't fall apart, and if taking 2 screws out is beyond one's ability, then by all means try one of the other kludge methods.
It's a hell of a lot easier than driving to the FLAPS, finding the switch, bringing it home, and installing it. How long does it take to remove 2 screws and pull out a light bulb? How much does it cost? How often do you need to do this?
Old 03-11-2011, 10:21 AM
Last question first...."how often do you need to do this?"....that shoud be the key question for someone thinking if this is too much trouble. The comparison is to "flipping" a switch, not going to the FLAPS to do the work ! Once you do the work, its's done, and done fairly correctly. It may be only me, but I don't consider dinking around and improving my car a "chore"....not my Porsche anyway.
It seems EVERY ( non-Porsche) car that has such a light ( think...hatchbacks) has a 2 position-switch on the light body itself, to be able to deactivate it. Fairly simple, but Porsche I guess never "got-it"...like most electrical things that they don't do very well....like forgetting to fuse stuff that should be fused.
Wanna talk about the 2-position ( vs 3-position) switch to operate the side-view mirrors? Another Porsche idiotic design that "moves" the mirror every time you accidentally brush the lever. Every other car has a middle "off" position that avoids this.
Wil Ferch
Old 03-11-2011, 10:37 AM
I like my battery quick disconnect at battery
Old 03-11-2011, 11:22 AM
Fine...sure this works, but then.....
no clock, needs to be reset later ... and you later need to also reset the stations on your radio..... why are we making this difficult?
Wil Ferch
Old 03-11-2011, 11:43 AM
N-Gruppe doesn't exist
teenerted1's Avatar
Location: *%@#ing GPS, where am I? Oh wait I see the Space Needle.
Send a message via AIM to teenerted1
this is too difficult for you guys that put in a switch or pull a fuse/bulb?
Ted
'70 911T 3.0L "SKIPPY" R-Gruppe #477
'73 914 2.0L SOLD bye bye "lil SMOKEY"
"Silence is Golden, but duct tape is SILVER.”
other flat fours:'77 VWBus 2.0L & 2002 ImprezaTS 2.5L
Old 03-11-2011, 03:17 PM
RETIRED
Joe Bob's Avatar
Nah....ignore me at yer peril.....
Old 03-11-2011, 03:28 PM
(1) finish coffee
(2) place under trunk lid
talk about easy peasy......
Old 03-11-2011, 04:21 PM
