-   -   Installing Wiring Loom Bullkhead Connectors (http://forums.pelicanparts.com/porsche-911-technical-forum/596463-installing-wiring-loom-bullkhead-connectors.html)
jluetjen 03-12-2011 11:20 AM
I'm in the process of replacing the burnt out wiring loom in my 69E. I've figured out how to get the circular bulkhead connectors out, but I'm having a hard time getting them installed. Is there a trick? I've tried pushing straight in, and starting one end and working it in, and neither approach has met with much success. I'd be interested in what others have found works.
Thanks! SmileWavy
Peterfrans 03-12-2011 11:54 AM
I use a heat gun on low setting to warm them up. With heat the plastic gets more pliable and you can get them in using a turning motion.
vwbobd 03-13-2011 05:09 AM
soapy solution worked for me
kodioneill 03-13-2011 05:13 AM
Rubber lube or silicone.
jluetjen 03-13-2011 02:15 PM
Thanks. Using a combination of both of those approaches the connector slid right in. Thanks!
