Front Turn Signal - where is the connector?
Hey Guys -
I've done a search, and could not find the answer. I was replacing the bulb in the left front turn signal housing, and noticed that one of the posts that the screw on the lens threads into was broken. So - I removed the fog light to give myself a space to work, and was able to get the housing off. But - I can't find the end of the wire - it disappears back into the car. I was able to remove the housing by un-doing all of the wires from the back of the reflector and getting them out the hole. So - anyone know how far back the connector is? I can tell you - I can't see it. Thanks, Ken |
it goes all the way back to the fuse box. No mid-line plug. Did you mark the wires so you know where they go back?
Well - that would have been smart, wouldn't it.
I know the gray/red wire is the park lights. I assume the black/green wire is the turn signal wire. I'm hoping the one I buy has the wires connected. So - when I take it apart, I'll note locations then. Thanks James. Ken |
| All times are GMT -8. The time now is 08:05 AM. |
