Plugging Early CIS Ports
I searched but could not find anything on this topic.
I have a 73.5 2.4T CIS motor that I am going to switch to carbs. How do I plug the CIS ports in the heads? I removed the plastic tubes and there is a threaded port that sticks through the shroud. Does this port that I see unscrew out of the heads? Is there a plug on the market for this purpose? TIA, Kev |
bump...c'mon guys. Lotta smart guys here, someone knows how to do this.
Kev
When I ran webers on my 73.5 I had the local engine builder make these. I gave him an injector and he made six plugs to those dimensions, with a threaded hole in the end so I could remove them when needed. I also modified the carb intake manifold to fit around the plugs so I could easily return it to cis. I am currently rebuilding the original engine and returning it to cis so I am glad I did. Cost me about $75.
Ed 1973.5 T |
Send the heads to Ollies and have him do it. Don't remember price but pretty cheap; kind of got lost in the noise of a valve job. Probably it can be done without pulling the heads, like Ed says above, but I have no experience with that.
jhtaylor santa barbara 74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's. 73 Targa (gone but not forgotten) |
![]() Let me know if you wanna unload those. Kev |
Sending PM
Ed 1973.5 T |
