Engine Comp. Fuse Block
180Deg. X 270 Deg. which way is which?
ok here it goes, I feel soooooo ashamed... The little fuse block in the engine compartment that has three fuses, Well I removed it when I refinished the mounting shelf and normally I would have wrote down the fuse amp sizes but for some unexplainable reason I didn't. I did record the wire locations in relation to the fuse block But, I also noticed Now!:( the fuse Block is bridged on the back side of the block which links 2 of the fuses together. So here are my Questions; 1. which way is the correct orientation of the fuse Block? 2. what are the ampre's of the Fuses and in what order? Thanks Boys and Girls.. Jorge (Targa Dude) :cool: |
1 Attachment(s)
Here you go.
Hope this helps. |
This is a perfect example of why this board rocks.
Nice work cary. |
Wow! no kidding this place most definately ROCKs BABY!..
Thanks Cary. it looks in the image that 23 and 24 are linked together, is this correct? I have plenty of those blue fuses but I can swear mine had a Red fuse in the mix too. all Smiles here (Targa Dude) :) |
Went and looked at the owners manual. #22 top one should be 5 amp. Opps.........
Without taking it off, can't see it. Does yours have that rivet/thread deal between 23 & 24. If I remember right, that it the bridge. 23 & 24 get their juice thru the generator. 22 gets it, from the Ignition module. :) |
Thanks Cary..
You are the Man!! Mine is exactly like yours. yes I do have the bridge between 23 and 24.. I'm am releaved... phew! ;) Jorge (Targa Dude) :cool: |
| All times are GMT -8. The time now is 11:56 AM. |
