Wind from central speaker hole
Hi.
I removed the center speaker and now enter a lot of wind from there.
Has anyone experienced the same?
I thought put some cloth ... any idea?
Tks
1970 911 T Targa
Old 10-20-2010, 10:46 AM
kfosburg's Avatar
Send a message via AIM to kfosburg Send a message via Yahoo to kfosburg
Same for me... search for floating speaker grills - it's been discussed before and comes down to leaking seals letting air into the trunk essentially.
Karl
Old 10-20-2010, 11:23 AM
jetstar911's Avatar
Buy some Dynamat. It comes in a pack containing two pieces. Both pieces are 12" by 12". Just cut to size then peel and stick from the underside of the dash. It will deaden the wind noise and block the draft.
Old 10-20-2010, 11:24 AM
Karl
That's it!!
Mine's floating too
Tks
1970 911 T Targa
Old 10-20-2010, 11:40 AM
HarryD's Avatar
I had the same problem. I cut a piece of cardboard to fit the hole and placed it under the speaker grill. No more leak.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 10-20-2010, 12:50 PM
For now I followed HarryD advice. I think is the quickest way to solve the levitating speaker grill.
Tomorrow I'll let you know if it worked.
1970 911 T Targa
Old 10-20-2010, 03:14 PM
JV44HeinzBar's Avatar
S!,
I've got this problem also. What is the best way to access the center speaker mount?
HB
Current:
1990 964c2 Grand Prix White: lowered, Big Reds, Big Fun!
1971 911 T Targa Signal Yellow (summer joy)
Past cars: 1970 911T Yellow, 1983 928, 1972 911 Targa emerald green
Old 03-18-2011, 06:55 AM
