Clunk noise
I've been looking at posts that identify a clunk noise while driving. I have a stock '82 SC. While I'm driving I can hear the clunk noise seemingly coming from the front wheels or shocks. I've taken the front bearings out and greased them, then tightened them according to spec. They looked perfect. I also just had the car on jack stands and pulled/jerked up and down, back and forth on the wheel, but I couldn't get any movement or noise. Is there something inside the shock that could be loose? How do I check it? Any pics would be great!
Old 03-15-2011, 05:07 PM
abit off center
cgarr's Avatar
What front struts do you have?
______________________
Craig
G2Performance
Old 03-15-2011, 05:11 PM
Inserts coming out of the struts?
good for a clunk.
Bruce
Old 03-15-2011, 06:10 PM
roll bar bushings or mountings?
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 03-15-2011, 06:27 PM
Member 911 Anonymous
DRACO A5OG's Avatar
If front, raise the car remove the suspect side and grab the strut, pull back and forth, if loose the strut nut if applicable needs to be tightened or the top strut nut. I would check both sides for movement.
'85 Carrera Targa
PCA/POC
Old 03-16-2011, 11:56 PM
KNS KNS is offline
+1 on roll bar bushings or mountings...
Kurt
Old 03-17-2011, 07:38 AM
WUNDERWAFFE
JINKATIN's Avatar
I had the similar issue, It was the spindle on the strut. Had to replace strut.
Hope this helps,
Charlie
1986 Carrera
Old 03-17-2011, 08:51 AM
yel911's Avatar
Maybe the rubber for the torsion bar mounts have had their days. Being an 82....
74' 911 w/3.2L (sold)
95' 993 C2 Triple Blk Cab.
02 Honda Superhawk (sold)
2018 Toyota Tundra Limited
2004 CRF250X
Old 03-17-2011, 11:05 AM
It seems that it could be the:
- Torsion bar
- Sway bar
- Strut
I need to do more investigation.
Old 03-17-2011, 09:05 PM
dshepp806's Avatar
I, too, am hearing a NEW similar sound from my right side,..but only when I apply brakes...will be looking this weekend....
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 03-18-2011, 06:37 AM
