-   -   Need Help for 2.7 Distributor (http://forums.pelicanparts.com/porsche-911-technical-forum/597396-need-help-2-7-distributor.html)
kyriakos59 03-17-2011 02:46 AM
:confused:I have a 1974 911 2.7 Carrera US SPECs K-Jetronic. The distributor needs rebuild. It goes up down a bit and also sideways. I also have a nice BOSCH distributor from a 2.7 RS engine (0 231 184 004).
I wonder whether I can replace the one on the motor with the RS distributor or use parts to fix the on one the engine. Please let me know whether this is possible or please recommend where to send the distributor for rebuild/repair.
ginot912 03-17-2011 03:17 AM
Do a search using "jerry woods" or call them Jerry Woods Enterprises 408-369- nine six zero seven
BTW do not mess with the 2.7 RS one.
Not sure if it would work with your motor. Others will chime in.
Gino
R_Builder 03-17-2011 06:21 AM
Barry Hershon, IAE Inc., (313) 532-5350.
ginot912 03-17-2011 07:38 AM
Hey R_Builder
Congrats on your 911 posts :)
Gino
BURN-BROS 03-17-2011 07:48 AM
The K jetronic distributors have a very mild curve to prevent detonation.
The RS curve would be too aggressive unless you have access to very good fuel. I would not recommend using the RS for your application.
I rebuild distributors for many shops here in the states and Canada.
ginot912 03-17-2011 07:55 AM
Burn-Bros
That's what I thought, but did not want to put foot in mouth.
When funds dictate, I might contact you, as I'm running a 2.4 dizzy in my 2.7 S cammed motor.
Gino
Still a newby
ClickClickBoom 03-17-2011 09:19 AM
Did the Jerry Woods rebuild on mine. Running 30deg full advance on the timing and 1.8% CO. Runs like a top fuel dragster, love it!
eric
BURN-BROS 03-17-2011 09:22 AM
Hi Gino,
The Jetronic systems were engineered to run relatively lean for emissions and fuel consumption. Carburetor /MFI type curves can be too aggressive.
I have a nice modified RS curve for carbureted engines as well as hybrid distributors for the 2.0-2.2 distributors that I can customize to any number of curves.
The distributors to use if you do not have are 0 231 184 xxx as these are the best overall design, exhibit little wear, very curvable.
The 0 231 169 xxx distributors are less than spectacular, and the curve can only be mildly tweaked. They seem to suffer more wear in the advance mechanisms.
RoninLB 03-17-2011 10:40 AM
The RS curve would be too aggressive.....
RS/.004 dizzy caused pinging under 3k when i had stock CIS intake, CIS cams and RS/8.5:1 pistons in summer temps unless gassed very gently
ginot912 03-18-2011 03:55 AM
Aaron
PM sent
Gino
