-   -   Removing coupe quarter windows (http://forums.pelicanparts.com/porsche-911-technical-forum/597423-removing-coupe-quarter-windows.html)
Shaun @ Tru6 03-17-2011 07:32 AM
How do you removed fixed quarterwindows on an 86 coupe so that the trim and window are not damaged? I've cut front and rear glass out, but this technique doesn't seem applicable to these windows.
juanbenae 03-17-2011 07:58 AM
they push out.its easiest to start them in a corner or at the back. ive done it a couple times and pushed from the inside and held the window from the outside from falling out. some soap or window cleaner on the inside between the body and rubber might help too. id spray or soap and let it sit for a few to run into the seam. it seems hair while your pushing but they do move w/o window breakage
juanbenae 03-17-2011 07:59 AM
push with a flat open hand
john walker's workshop 03-17-2011 08:08 AM
i start by using about 4 small screwdrivers inserted around the back curve, behind the rubber, two on the top, two on the bottom, then pull them down near the glass and push them in behind the body seam to keep the rubber pulled away from the headliner. then push hard with your palm.
Wil Ferch 03-17-2011 09:42 AM
Rear/side quarter windows?.....front fixed-vent "quarter windows"...... ????
yel911 03-17-2011 11:02 AM
Shaun, sit in the backseat and push out.... Have someone outside ready to help when the seal is past the body. I installed/removed Chris B's.
Shaun @ Tru6 03-18-2011 06:13 AM
Thanks for all the replies, getting these out tomorrow.
El_Mecanico 03-19-2011 06:19 PM
First pull the rubber weatherstrip from the rivet...it along the door jam. In the inside just lift the seal so its between the glass and steel edge. Than push slowing from the rear curve side she will slowing come out. You do not need to remove the trim. If its original you will have the puddy body tape...so be easy you dont want to break the glass. The seal is also very expensive.
