wierd 3.2 problem
here's a wierd problem for you all. 86 carrera won't start. pull off any one injector plug and it runs. i ran into this problem years ago but i can't remember what fixed it. a customer called me on the phone about it, so i thought i would post it, and maybe when i come in tomorrow morning, someone who had the same problem will have enlightened me. thanks.
John,
This is not good. If one of the head "guru's" on the list does not know the answer, then we mere mortals would have a rough time with it! Possibly a grounding or electrical problem that taking one injector plug out of the loop would make it work? How would taking one injector out of the loop interface with the DME computer and could this be part of the problem? Does it matter which injector you pull off? Wiring harness? Just an idea... Joe |
I'll take a look in my Bentley for ya, John :D :D :D
Maybe a bad ground on the injector harness. Doesn't the ground point bolt onto the manifold?
Why would interrupting the circut on a injector make any difference? Wonder if a diode has gone bad and is backfeeding a relay with power or the like and taking the lead off makes it work? Taking the injector lead off could effect a ground on the DME computer?
This one is weird... but challenging. JA |
DME problem. Tell the guy to check for dampness in the dme area. Sounds like too much combined resistance for the computer, and by unplugging any injector, you bring down the total injector resistance to the dme unit. but.. Is it a pulse to the injector that is missing upon no start or 12v?
Mike 86 Carrera t |
John,
I don't know if this will help but it seemed relevant: Don Istook posted this in Aug 1999 about 944's: Quote:
Martin (porsche@globe.net.nz) posted this in May of 2000: Quote:
this car isn't in the shop so i can't check it out. it's a ferry ride away in bremerton, so i'm trying to help the guy over the phone. he has replaced the DME relay, the grounds are tight on the manifold, the sensor plugs are clean and tight, the car has been stored inside for 6 months, so the computer didn't get wet, and it ran ok before. i suggested he check for a pulse at the injector plug, and that's when the car started for him. so it must not have much, if any pulse with them all plugged in, and sufficient pulse with one unplugged to run the rest. i suspect the computer, and it would be easy to plug in my test unit IF the car was here. guess he'll have to tow it in. keep thinking though.
| All times are GMT -8. The time now is 05:54 AM. |
