Help I dropped the SC Ignition
Took my ignition out of my SC this past weekend. Don't know which wire goes where. Let me explain. At the time I removed the ignition after removing the shear bolts and while pushing the assembly out of the dash, the two wires that attach on the dual plastic clipped terminal next to the larger main plug at the back broke off. Now I don't know which one goes onto which of the two terminals. Could anyone out there with a color chart or just happens to know tell me which color/stripe wire goes where? That is to say, which color combo wire goes on closest to the main harness plug on the back of the switch? The other wire will obviously go onto the furthest terminal.
Antares |
Don't know if this will help. Shooting blindly under the dash at 6:00 AM.
Robert Stoll 83 911 SC 83 944 |
that's the key buzzer contact. you should be happy it's gone. if you REALLY want to fix it, it doesn't matter which way they go on.
Thanks alot guys ... ahh it's those little things that ... well you know.
Antares |
