-   -   Trailing arm conversion stub axle question (http://forums.pelicanparts.com/porsche-911-technical-forum/597782-trailing-arm-conversion-stub-axle-question.html)
Phrog 03-19-2011 09:21 AM
I'm converting from steel to aluminum trailing arms and want to know if an early 1971 stub axle will work with a later 1983 hub? The splines fit fine but I question if the axles will match with the wheel bearings.
