9112.2t's Avatar
Zenith Carb Rebuild?
I am rebuilding a pair of Zenith 40 tins and am wondering should I be using some sort of anti-seize for the threads on the different screws? Idle and others? Lock tight for the little screws on the butterflies or any other recommended items??? I am deleting the enrichment ckt. Also is there a torque pattern or recommendations? Or any kind of gasket sealant?
Thank You.
Old 03-19-2011, 12:52 PM
Senior Advisor
James Brown's Avatar
No loctite needed, maybe on the butterflies, no gasket sealant needed, tighten down the top snug all around then go back tighten down a little more. The enrichment circuit can be sealed with RTV and vacuum plugs.
08 Cayenne Turbo
Old 03-19-2011, 01:51 PM
