NutmegCarrera's Avatar
Location: Plymouth Wi. - Spitting distance from Road America
Distributor cap & wires question
Dumb question, but feel there is merit asking:
1. When replacing a rotor and cap, I assume the whole works should be assembled "dry", e.g. - no dielectric grease on the rotor. Right?
2. When installing new wires to that cap, these should also be "dry"?
For reference, this is a 1985 with 3.2 I'm doing a cyl head temp sensor, new cap & rotor and Clewett wires. PO history is unclear - but from the little I know, none of this stuff has been done for a long time. Last year (my first real season with the car) I was able to get the WOT sensor working, throttle linkage adjusted, and did the "adjustment" of the flapper wiper in the air sensor (get the contacts onto a clean part of the strip). Also have new fuel filter, new plugs (copper core), etc... Also put an o-scope on the o2 sensor, and that seems to be ok as-is.
So- The current roughness (mainly at idle) is hopefully going to be gone. Can't wait to see the results.
Thanks for any input.
Old 03-19-2011, 07:31 PM
steely's Avatar
Dry here. no dielectric.
You might want to put a little 3 in 1 oil on the felt pad in the ctr before installing the rotor on top.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 03-19-2011, 07:50 PM
John W
I like to use a little SIL-GLYDE on the rubber boots where they contact the distributor cap to make it a little easier to get them off the next time.
John
89 3.2 Targa 123k miles
Old 03-19-2011, 08:05 PM
