-   -   Fluid in bottom of speedometer? (http://forums.pelicanparts.com/porsche-911-technical-forum/597885-fluid-bottom-speedometer.html)
rsnodgrass 03-19-2011 07:18 PM
What would cause fluid to accumulate at the bottom of the speedometer? It looks like it was slightly greasy and has been gone for a while, but you can still see slight discoloration on the white parts at the bottom of the gauge. Any ideas? I figured it must be the sender leaking.
john walker's workshop 03-19-2011 07:53 PM
gear oil coming up the cable.
rsnodgrass 03-19-2011 08:08 PM
Thanks John. I guess the cable must need to be changed.
Joe Bob 03-19-2011 08:36 PM
Cable has a seal that can fail. It keeps the oil from being wicked up from the trans to the gauge.
You'll need to clean out the crud in the gauge.
