coming out of winter storage
Hi guys OK, its getting close to that time of year when I am getting ready to pull my 82 SC out of the garage for summer.
Still new at this and wondering what hits or tips might help make the transition a little easier on the car. Stabilized the fuel, changed the oil and drained the windshield/headlight washer fluid and parked it in the garage last fall. Basically last year I put the battery charger on for a couple hours and turned her over turned out good for me but thinking there might be some better guidelines to follow this spring. Thanks
I've driven alot of crap to get here man! |
I've basically done that....with some variations ( sometimes on jackstands...allowing running not only the motor, but also allowing the gearbox to be engaged.....when I run the car in winter)......for over 17 years with no issues.
I've been criticised for doing this....people say better to put it into "dead" storage.....but my "twist" was that when I *do* run the engine...I would run the engine until warm and up to temp...and THEN at least another 30-40 minutes. Did this maybe every 2 weeks, sometimes longer, sometimes shorter. At aboiut 2000 rpm...not idle speed. 911 engines don't lube well at prolonged idle speed. Car is laid up at least 5 months for a Buffalo winter.....had no issues. I'm sure you will encounter some counter-points to this....but there you are. I figured "dead" storage allows a lot of oil and oil film to drain low and leave topside of engine bits and pieces and cams..maybe totally dry. It's kinda a crap-shoot, but my feeling was the car would be better "exercised" every so-often as long as it went beyond bringing it up to temp.
Wil Ferch 85 Carrera ( gone, but not forgotten ) Last edited by Wil Ferch; 03-20-2011 at 08:27 AM.. |
For just a winter rest it sounds like you've covered the basics - get in and drive. Just go easy on it for a while till she comes fully up to temp.
Kurt |
I like to disable the fuel pump and ignition and crank the engine for a few seconds till I see oil pressure. After that I just reconnect everything and start it up. I also like to check the tire pressure.
Ed 1973.5 T |
Just brought my 87 Cab home from storage earlier today. I had pulled battery, filled tank + Stabil and over-inflated tires - about 45psi. I just took some air out of the tires, put in the battery and it started right up....even without a puff of smoke.
Tonight I changed the oil and filter and went for a 40 mile drive...so happy to have her back.....
1987 Triple Black Cabriolet - Wide Body 2011 Black Cadillac SRX 2007 Black Honda Element SC 5spd (for sale!) 2015 Yukon XL Denali 1966 VW Karmann Ghia |
Aaaarrgh!!
Weather man says we have another snow storm and below average temps coming our way again this week
