Olivier 3.0's Avatar
Send a message via ICQ to Olivier 3.0
Red face oil level sender: stupid question , but ...
my oil level sender (in the fender) is out ... So, I'm about to change it, and I refer to the Wayne's "101 projects"... It is not mentionned, but : do I have to sump the oil from the tank before, or is the gauge higher than the oil level?
And how to get the sender away from the tank (do I have to use a screwdriver) ? there is no way to grab it ...
Olivier.
'76 Carrera 3.0
Old 02-10-2002, 10:42 AM
AirCooledExcellence's Avatar
Hi Olivier,
You don't have to drain the tank first, and to remove it just undo all the bolts, disconnect the wires and carefully pull the sensor out of the hole. It's a bit tricky but you should get it out in no time.
Cheers,
Tim.
____________
1983 SC Targa
Old 02-10-2002, 11:13 AM
Glasgow 911SC's Avatar
Before you buy a new one you should make sure that there is a fault with it (if you haven't already). I changed mine when my gauge started to read full all the time, but it still doesn't work.
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 02-10-2002, 11:27 AM
cary's Avatar
Olivier, check those "dinky & thin' wires first.
If you ground the signal wire, it should "peg" the gauge. Can't remember which is which, sorry. That tells you that the wires and the gauge are good.
And check the solder connections on the push on connectors going to the float.
Good Luck
Cary
77 Carrera RS w/3.2 #59
73 914S 2.0 AG
73 914 1.7 Driver ( daily driver, under complete rustoration )
74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor
Old 02-10-2002, 01:12 PM
Smile
thanks...
I've already changed the wire connectors, and cleaned everything... I'll check the signal wire, but I'm not sure I clearly understood (infact, I do not unstand "peg" ) : my needle is already "sticked" at the top of the gauge; when i'll put the signal to the ground, will it go to the bottom or stay at the top??
furthermore, it sometimes works again; is it a clue about the fact that the guilty may be the gauge ?
Olivier.
'76 Carrera 3.0
Old 02-11-2002, 05:29 AM
cary's Avatar
peg = all the way to the top, sorry.
When you unplug the wire. It should drop the needle back down to the bottom. Then ground the wire and in should go back to the top.
Cary
73 914S 2.0 AG
Old 02-11-2002, 05:36 AM
well, I checked, and the needle is always "pegged" (I 'm learning !) , whenever the signal wire is connected or not to the sender; the only way to make the needle go down is to unplug the + wire directly at the dashboard gauge (or obviously switch off the ignition) ...
Does it mean that there is a "ground" point somewhere between the gauge and the sender?
Olivier.
'76 Carrera 3.0
Old 02-13-2002, 03:05 PM
cary's Avatar
Before we over react. Switch the wires on the tank and see what you get.
When I changed the gasket on the tank. I hooked it up backwards and it "pegged" the gauge.
See what you get.
Cary
73 914S 2.0 AG
Old 02-13-2002, 03:23 PM
stormcrow's Avatar
I think your sending unit at the tank is set up like a rehostat. What you can do to check it is connect the + terminal to one side of the sending unit. With a VOM switch to the dc volt reading and connect one terminal to the other therminal on the switch and connect the other terminal to the wire. Raise and lower the float. If the voltage changes then your sending unit is ok. The problem is then at the gauge.
--(12V+)--(SU)--(VOM)--(12V- or ground)
SU - Sending Unit (tank float)
VOM - Volt/Ohm/Meter
Hope this info helps.
Old 02-13-2002, 03:41 PM
